Sources For Separator Material - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-18-2012, 10:17 PM   #1
sources for separator material
Where can I purchase the spacer/sealer material used between the panes of glass in dual pane windows
Ralph Taylor is offline   Reply With Quote
Old 01-18-2012, 10:25 PM   #2
Rewards Points: 13,450
And what would you do with it if you could?
If your thinking about making your own double paned windows it's not going to happen. The glass will fog up between the panes.
HomeSealed (01-19-2012)
Old 01-19-2012, 06:35 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,092
Contact the manufacturer on the windows or a local glazing shop.
This is not usually a DIY'er project.
Old 01-19-2012, 07:46 AM   #4
DIY staff
Rewards Points: 7,174
Many glass shops send that work out to be done by a specialty shop---
Sources for kitchen garden window? Eric in NC General DIY Discussions 11 06-06-2014 09:03 PM
Beadboard ceiling: inexpensive sources for 4x10 planks? sonyah Carpentry 2 08-12-2011 10:42 PM
two lights two sources one switch bgbur98 Electrical 1 01-30-2011 07:48 PM
Can a Load Have Two Power Sources? Starlight Electrical 5 10-05-2010 10:26 AM
3 way switch - two sources szmaria Electrical 7 02-09-2010 10:42 AM
