Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 11-26-2012, 05:05 PM   #1
Sound dampening door
My office reno is done to the point where I'm now looking into (interior) doors. I spent a lot of time and money soundproofing the room and don't want to diminish diminish the effort at this point.
I do, however, need to go with 32" paneled doors. Two doors will create a sound dampening air space, but there is a laundry room between the two doors just outside my office door. (I may have to go S.C. non-paneled with that one, but I'd really prefer not to...).
I know they make solid core paneled doors. Are these better for sound? I'm trying to balance sound dampening with appearance. ANy other suggestions (I'll be addressing the threshold issue as well).
Thanks!
rightit is offline   Reply With Quote
Old 11-27-2012, 07:50 AM   #2
Exterior Construction
Windows on Wash's Avatar
I can't say for certain, however, the solid core door should have a lesser STC rating via it solid nature.
If you look at stud walls comparisons, steel stud walls (i.e. less material and less solid) out perform wood framed walls.
The Following User Says Thank You to Windows on Wash For This Useful Post:
rightit (11-27-2012)
Old 11-27-2012, 12:20 PM   #3
Hi Windows...hope all is well. In reviewing, my question was poorly phrased. Mass is always good for dampening sound. I'm just not sure (in the paneled doors) weather there's any difference (as there would be with non-paneled slabs). Could be a moot question. Thanks for responding and nice to see you here.
Mark
Old 11-27-2012, 02:01 PM   #4
I can't imagine the characters any real perceptible sound mitigation difference between a paneled and on paneled slab.
Hollow versus foamcore will probably make a more impactful difference in the sound mitigation.
Old 11-27-2012, 05:12 PM   #5
Windows & Remodeling
HomeSealed's Avatar
Are you just installing standard interior doors, or are you taking any measures to seal them when closed? That would help as well.
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Old 11-27-2012, 06:43 PM   #6
Thanks for the tip. I plan on putting in a door sweep for now, but may install an auto threshold if needed (and door gasketting as well, if needed).
Leaking Door JaneD Windows and Doors 2 06-15-2011 09:22 PM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 06:45 PM
Sound proof door wedge22 Building & Construction 6 09-22-2008 01:21 AM
Sound dampening beings Carpentry 4 07-26-2008 05:50 PM
