Solution For Old Wooden Window Sill - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-21-2012, 11:13 AM   #1
hohadcr's Avatar
Rewards Points: 346
solution for old wooden window sill
Hi, I have some old windows. Outer layer is aluminum, inner layer is original wooden window. Inbetween, it is the old wooden sill. Over the years, the wooden sill caught water is getting soft.
I know I should change the windwo into PVC ones. But before spending so much money, is there a way to cover the wooden sill with pvc or something to avoid further damage?
Here is a pic showing the situation. Some windows have a lot worse damage than the pic.
=====New question=====
I am going to replace the window. With the rotten sill, should I replace the frame as well?
Any instruction on replacing the window frame and the window?
hohadcr is offline   Reply With Quote
Old 05-21-2012, 11:35 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
You could cap it but that is not a good DIY'er project and you will have to remove the storms to do it properly.
DIY project would be wood repair and paint.
Old 05-21-2012, 11:51 AM   #3
hohadcr's Avatar
Rewards Points: 346
My goal was to find a cheaper temp solution.
How much usually should capping cost? Would it make more sense to just change it?
Old 05-22-2012, 07:38 AM   #4
Painting will be your cheapest followed by capping and followed by replacement.
Don't cap over any rotted wood though.
Old 05-22-2012, 09:12 AM   #5
hohadcr's Avatar
Rewards Points: 346
the wood is too rodden to hold the paint now. Does it make sense to cap? All depends on the cost of capping
Old 05-22-2012, 09:31 AM   #6
No.
Don't cap rotted wood.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
HomeSealed (05-23-2012), Tom Struble (05-22-2012)
Old 05-22-2012, 08:28 PM   #7
hohadcr's Avatar
Rewards Points: 346
so, really, only way to go is to change them into new windows.,
Old 05-22-2012, 10:23 PM   #8
By the time you figure on the carpentry work to fix them, you might be better suited.
Old 05-22-2012, 11:57 PM   #9
How did water penetrate through the aluminum and damage the wood?
JackOfAllTrades is offline   Reply With Quote
Old 06-02-2012, 11:47 AM   #10
hohadcr's Avatar
Rewards Points: 346
To JackOfAllTrades, a lot of times, the aluminum outer window is left open and only the innner wooden window is closed. So water accumulate on the wooden sill.
New question
Thx
Old 06-02-2012, 11:50 AM   #11
You can replace the sill without doing a full tear out but if it is rotted completely out, sometime a full tear out is easier.
Not a great DIY'er job but look around online and you will find some recommendations and videos.
Old 06-02-2012, 02:29 PM   #12
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+1. It depends how bad it is, but you really don't ever want to leave bad wood in there.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Window treatment options? bokeh Interior Decorating 15 05-20-2017 10:04 PM
Moisture on drywall and window sill redwings83 General DIY Discussions 4 09-26-2011 04:11 PM
Window sill recess 4 a brick wall RedBear Building & Construction 0 07-17-2011 09:53 PM
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
Drip edge on bottom side of window sill... Windows Remodeling 2 03-22-2010 01:40 AM
