Soft Lite Quote
I don't sell much softlite , but that sounds about right. I generally like to see a .28 or better from a double pane, and without a really heavy dose of low-e that would lower the SHGC too much for your area. The better lines in HiMark and SL are getting .25, .26, .27 and with SHGC's above .25 even with grids. Be sure to consider the air infiltration ratings as well.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
