#1 |
small hole repair - interior door
So my 3 yr old son decided to open the basement door the wrong way and the stop busted thru the door. The inside of the door is hollow. Any suggestions on how to repair are much appreciated.
#2 |
http://www.waterputty.com/
Then sand prime and paint. |
#3 |
Average Joe/ex-Navy IC3
Basement door, if you have a furnace down there, you may want to replace that cheap hollow core, with a door, that has a longer burn time, just in case something does happen. Plus side, a solid core door will not ding so easy. If all of your doors are standard sized doors, I would definitely look at replacing them with solid core doors, so they can stand up to the abuse that kids can put on them.
Plus side is, they would add resale value to your place if you ever decide to sell later on.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
| The Following User Says Thank You to gregzoll For This Useful Post: | brianxmurray (02-18-2013) |
| Display Modes | |
| Repair Small Hole in Vinyl Siding | Silkcityflorida | General Discussion | 12 | 04-08-2013 04:34 PM |
| Small hole in finished floor | DDASH | Flooring | 4 | 12-22-2011 06:55 PM |
| Small Engine Repair Two | Lamentations | General Discussion | 3 | 01-30-2009 03:10 PM |
| small engine repair | oletrkguy | General Discussion | 24 | 12-08-2008 06:04 AM |
| I hope I don't have to tear down the ceiling | brds16 | Carpentry | 9 | 04-30-2005 11:16 AM |
