#1 |
Household Handyman
Sliding window repair
Here's the scenario: We have a sliding, aluminum framed, double-paned, window at work which we open to wait on customers. One side is fixed, one side moves. This is within a large manufacturing facility, and we supply the fasteners, cutting tools, personal safety items, and much more. The window became very hard to slide, right to left, so I took it out to clean the tracks and a good inspection. You just lift it up a bit, bring the bottom section out to you, and the sliding section comes completely out. There are two plastic housings on the bottom, which "pop" into the window frame and these have one roller each within them. The rollers have flat spots, and the pins/axles are worn really bad, the plastic housing is in good condition.Therefore the window just slides on the bottom of the frame. I cannot find anything on this window to state the manufacturers name, just the safety glass info. I searched the net and found so man different types of these plastic brackets with rollers in them, but none match or are even close. Hoping someone out there could recommend a supplier of parts for these type sliding windows, Thanks, David
#2 |
Moderator
Alum. frame still have a few parts at box stores or better, older hardware stores that they didn't run out of business yet. Try Ace, too.
Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Display Modes | |
| Best Way Repair This Window Sill ? | markee | Building & Construction | 11 | 10-10-2012 06:40 PM |
| Inside Window Repair and Refinish | mibson | Building & Construction | 0 | 02-13-2011 11:28 AM |
| Bay Window roof repair | sklynstra | Roofing/Siding | 2 | 02-05-2011 03:52 PM |
| Window Leak: Flashing or Window? | lverma | Building & Construction | 16 | 08-31-2010 01:46 PM |
| Bathroom window issues? | Mantaray14 | Remodeling | 11 | 12-04-2009 08:40 PM |
