Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 07-11-2012, 07:18 PM   #1
Sliding Screen Door -- Getting it Back In
Hello,
I had a screen sliding screen door that was not sliding. I decided to remove it and replace the rollers. It was a chore to get it out. But I did.
The problem is that there are plastic moldings that make it very tough to get the door in. Even without the rollers (I removed both the top and bottom sets) - the frame won't go into place. So having to compress the rollers will only make this even harder.
The moldings are plastic U-shaped and the outer face is blocking me from getting the bottom into the track. If it weren't there - I could just compress the roller and pop it onto the track.
The tracks seem level and okay since the heavy glass door glides well.
Any ideas / tips / experience?
I am tempted to get a Dremmel and grind away the darned molding.
The Fez is offline   Reply With Quote
Old 07-11-2012, 08:53 PM   #2
Tom Struble's Avatar
pictures?
Tom Struble is offline   Reply With Quote
Old 07-11-2012, 09:19 PM   #3
Photos of the top and bottom track are here
Name:  scrn top track.jpg
and here
Name:  scrn bot track.jpg
Old 07-11-2012, 09:51 PM   #4
Super Moderator
Sounds to me like that is the wrong screen door for that opening---what brand of door?
Old 07-11-2012, 11:21 PM   #5
Bay Mills I think given the type of rollers I had to buy.
Old 07-12-2012, 12:08 AM   #6
Some sliding doors and screens can be put back by just inserting it into the top track pushing up, and then you should have enough room on the lower track to tilt it in place without removing any trim.
epson is offline   Reply With Quote
Old 07-12-2012, 01:28 PM   #7
Yes, I understand that's "theory" --- I posted here because in this case you cannot simply lift the wheels and tip the door onto the track. You can't get the door over the trim without really wailing on it.
Old 07-12-2012, 04:37 PM   #8
what kind of door? any labels?
Old 07-12-2012, 04:53 PM   #9
No, no labels so I cannot tell. However as I mentioned above - given the type of rollers, I think it may be a Bay Mills here's a picture of the roller in a link that talks about Bay Mills
http://www.nextag.com/Prime-Line-Ste...55/prices-html
Although, does it matter? Seems like whatever it is - it is. I just don't know a trick for getting it back in without really bending stuff up.
Old 07-12-2012, 07:44 PM   #10
Super Moderator
You never answered the question---the PATIO door--do you know what brand that is--you have the wrong screen---
Sounds like you have a Chevy patio door with a Ford screen----
Old 07-12-2012, 07:58 PM   #11
i take it you removed the screen to put new rollers in and now you can't reinstall it because now it seems too large?...this correct?your sure your putting it in the right track at the top and the right groove on the bottom?
are there roller adjustment screws in holes at the sides of the screen frame?
apparently it does matter now don't it?
Finding window screen for garage window daluu Windows and Doors 9 07-09-2012 04:01 PM
Help with sliding glass doors. ob2s Windows and Doors 8 05-30-2012 09:54 AM
sliding woodframe glass doors stephenbishop Windows and Doors 1 03-13-2012 08:11 AM
Sump pump back up DennyF Plumbing 4 02-17-2012 02:58 PM
Arc fault light briefly lit when turning circuit back on... darthsmozers Electrical 26 01-16-2012 11:04 AM
