Sliding Patio Door Won't Completely Close - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-28-2011, 08:01 PM   #1
Sliding patio door won't completely close
The patio door glides along like it has on ice skates...yet will push back at the locking side as if a magnet were pulling it open. The rollers appear to be clean, I poked around the top and bottom thinking something was dirt or so and found nothing. What could be causing this? How would I fix it?
I appreciate any help
Thanks much
wobblybox is offline   Reply With Quote
Old 12-28-2011, 08:25 PM   #2
did you check the bottom track to see if its level?
Old 12-28-2011, 08:29 PM   #3
Rewards Points: 12,858
I'm inclined to think it's the header that's out of level. The bottom rail just acts to keep the door panels aligned.
Old 12-28-2011, 09:07 PM   #4
Patio slider
Okay, here's the deal... I'm a female (not that it should matter, but I'm of the age where dad didn't exactly call me over while fixing stuffs)
I'm pretty good with learning new things, yet would checking the level mean using my level to see if it's out of plumb now?
Old 12-28-2011, 11:34 PM   #5
yes. check the track and the header both. a few photos might help also
Old 12-29-2011, 08:33 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 894
+1 on pictures and perhaps a bit more details.
Looking for Recommendations RE: Sliding Patio Door Greg D Building & Construction 4 09-10-2011 11:29 AM
Pull down attic stairs will not close completely gmalafarina Building & Construction 2 12-05-2010 11:09 AM
Flapper valve infrequently doesn't completely close Yoyizit Plumbing 4 08-30-2010 04:54 PM
Ice dispenser door does not completely close Larry Altherr Appliances 1 07-15-2010 12:39 PM
Window won't close completely bucksone General DIY Discussions 3 06-25-2009 06:57 AM
