I just had an Anderson A400 sliding door installed by home depot that was put on top of my concrete slab foundation. There are 2 things that I'm skeptical of after the installer put it in:
1- A few beads of silicone where put on the concrete foundation and then the patio door put in- is there any other type of flashing necessary on the bottom for a concrete installation?
2- The sill pan is flush on the left side and recessed inward about a 1/4 inch on the right side without an overhang. The installer said it was because the foundation wasn't angled straight. Picture attached....does that look right? I put the silicone down you see in the picture as a precaution.
Should I calling them to correctly install or does this sound adequate? Thanks
