Single Sided Deadbolt - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-16-2013, 03:05 PM   #1
Single sided deadbolt
Hey folks,
I have a new metal entry door with wood sides. It's pre drilled for knob and deadbolt. I wanted to install an additional single sided deadbold. The factory drilled holes had wood under the metal skin. I incorrectly assumed the wood would go high enough to put another hole, but it's just foam.
Is a second bolt in this area not recommended? Has anyone else done this? Any way (or need) to reinforce?
Thanks!
no drain blues is offline   Reply With Quote
Old 03-16-2013, 03:45 PM   #2
Rewards Points: 13,276
Why would you even want to add one?
gregzoll (03-18-2013)
Old 03-16-2013, 03:56 PM   #3
My deadbolts are keyed on both sides, I want to add a thumb latch so I don't have to fumble with the key all the time on inside.
Old 03-16-2013, 06:17 PM   #4
Rewards Points: 2,238
Change the inside to a knob/latch -
the dead-bolt.
A dead-bolt, through the foam is useless -
It looks impressive, though.
rossfingal is offline   Reply With Quote
Old 03-18-2013, 07:20 AM   #5
The door has already been cut, can't change style.
Old 03-18-2013, 08:48 AM   #6
Rewards Points: 6,652
Just pick up a new lockset with handle & deadbolt and be done. Then just keep the other in a plastic bag with the parts & keys, or donate to local Habitat store for someone else to buy.
Old 03-18-2013, 08:50 AM   #7
A keyed both side is againt code in my area.
What do you do if there's a fire? Go looking for your keys?
oh'mike (05-16-2013)
Old 03-21-2013, 02:42 PM   #8
Mold!! Let's kill it!
Rewards Points: 2,012
Take a wood chisel and remove some of the foam core from the top and bottom of the hole. Cut some wood blocking that fits snuggly from one skin to the other. 1/2 inch plywood blocks about an inch wide work. Use at least one in the top and one in the bottom. More is better if you can get them in around the perimeter of the hole. When you tighten the clamp screws on the deadbolt, it will pinch the wood blocks between the metal skins and they won't move. Without the blocks, the core will just crush together and the lock will never be tight. There was a company that used to sell a corrugated metal expander for this purpose, but I've not seen any in years.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
no drain blues (05-15-2013)
Old 05-15-2013, 11:20 PM   #9
Thanks M6!
I was able to find some small pieces of exhaust pipe that was the exact diameter I needed. I cut it to fit and machined a couple holes for the deadbolt to slip through. Was only about 5 dollars and about 30min to get it all machined.
I'll try and post a few pictures.
Thanks again!
The Following User Says Thank You to no drain blues For This Useful Post:
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Replacing 2 handle faucet with single handle faucet vcheez Plumbing 6 10-19-2011 11:26 AM
Geothermal single stage vs two stage JMH18 HVAC 3 08-13-2011 10:22 AM
Need Help... Single Pole Wiring - Timer abcdefg611999 Electrical 2 07-10-2011 05:39 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
