Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 10-16-2011, 08:59 PM   #1
single pane window insulation
i have single pane windows and want to reduce heat loss in the winter. does the heat shrink window treatments effective and i have also heard that bubble wrap can be helpful. any feedback appreciated
batwomen is offline   Reply With Quote
Old 10-16-2011, 09:39 PM   #2
Exterior Construction
Windows on Wash's Avatar
Heat shrink plastic can be effective if installed properly. Not sure that I like the idea of highly flammable plastic on the inside surface of home though.
Have you considered storm windows? It is a bit more permanent solution the heat loss issue and you can get them with Low-e so that it works in the cooling months as well.
Where is the home located?
Help Replacing Window Pane rosco Carpentry 5 02-21-2011 09:20 AM
Rotted window frame bottom: Do I need to replace the whole window? Ginette Building & Construction 4 09-15-2010 09:52 AM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Cannot lock Single Hung Gerkin Window ArchieT Building & Construction 13 07-02-2009 09:24 AM
Shrink film window insulation, no kit EscarHolmez General Discussion 3 12-28-2008 01:05 PM
