-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   single pane window insulation (http://www.diychatroom.com/f104/single-pane-window-insulation-120330/)
batwomen 10-16-2011 07:59 PM
i have single pane windows and want to reduce heat loss in the winter. does the heat shrink window treatments effective and i have also heard that bubble wrap can be helpful. any feedback appreciated
Windows on Wash 10-16-2011 08:39 PM
Heat shrink plastic can be effective if installed properly. Not sure that I like the idea of highly flammable plastic on the inside surface of home though.
Have you considered storm windows? It is a bit more permanent solution the heat loss issue and you can get them with Low-e so that it works in the cooling months as well.
Where is the home located?
