Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 12-12-2012, 02:07 PM   #1
Simple Storm Door, screw question
This is a very simple question I believe, but, Im new to this stuff and typically get caught up in the details.
I recently installed a storm door but because I have no brick mold (rather the foam, stucco) trim around my door, I had to notch that out and install over this. It turned out really well, but, the #8 1-in. screws wouldn't do the trick when installing the frame due to the foam I had to go over. I had some 3-in drywall screws that I used in the interim just to get the thing hung. Now, my question, I want to replace the drywall screws (since they will rust) with #8 3-in. screws. Should these be sheet metal screws or wood screws?
Are either of these fine:
http://www.fastenal.com/web/products...ex?sku=0171825
or
http://www.mcmaster.com/#pull-out-re...screws/=kka6vn
SER56 is offline   Reply With Quote
Old 12-12-2012, 02:33 PM   #2
Exterior Construction
Windows on Wash's Avatar
Don't see a real difference in either. Tomato...tomatoe...
I know there are some purist that will say that is wrong but get a pan head stainless regardless.
The Following User Says Thank You to Windows on Wash For This Useful Post:
SER56 (12-12-2012)
Old 12-13-2012, 03:31 PM   #3
Moderator
kwikfishron's Avatar
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 12-15-2012, 11:07 AM   #4
Originally Posted by kwikfishron View Post
You know its coming...
Old 12-15-2012, 11:35 AM   #5
Pan head would look the best, Stainless is a soft metal so I would predill a pilot hole to make sure the heads did not cam out on you.
Most wood screws will have a flat head and look like poop.
SER56 (12-15-2012)
Old 12-15-2012, 12:38 PM   #6
Haverhill Trade 1965
Assuming it is an aluminum door they come with aluminum screws. You can use stainless or aluminum in the appropriate length but never galvanized. Aluminum, zinc, and water do not go together over time.
Duckweather is offline   Reply With Quote
The Following User Says Thank You to Duckweather For This Useful Post:
SER56 (12-15-2012)
Old 12-24-2012, 09:20 AM   #7
This. Panhead or hex head.
huesmann is offline   Reply With Quote
Old 12-25-2012, 06:10 PM   #8
Household Handyman
Odd--I work part-time for Fastenal. Guess which screw I would recommend? Pre-drilling for the SS screws is a very good idea. Yes, Stainless Steel screws are softer than most other screws--Believe it or not.
Old 12-26-2012, 08:57 AM   #9
We use your stuff quite often.
Good company to deal with!!
Merry Belated Christmas.
Question on Storm Door lock latch Noel8 General Discussion 4 09-19-2012 12:48 PM
Simple grounding question fgunternahrer Electrical 7 09-04-2012 06:43 PM
Simple question on transformers from a n00b turborunner Electrical 4 06-13-2012 12:49 AM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
simple question djcrewz Electrical 7 10-25-2005 12:01 PM
