Simonton Sliding Patio Door Removal - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 02:36 PM   #1
Hi, as the title says I trying to figure out how to remove my patio sliding door door. I've looked at the sliding door and it has a cover/tab that I believe needs to be popped off at the top and bottom of the door. I've attached a picture below to show what I'm talking about. I've tried prying it off with a screwdriver, but it's on pretty tight so I'm not sure it's truly removable. Any help would be appreciated.
mrdave100 is offline   Reply With Quote
Old 07-07-2013, 08:28 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,728
That's probably a lifting limit device.
Simonton has really good information on their website. Have you tried there yet?
Probably need to pop that out and then you will be able to lift the door out.
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 05:20 AM
Whistling sliding patio door stressfreak Insulation 5 11-24-2011 09:01 PM
What is a 'concrete sill' for a sliding patio door? mikedavid00 Building & Construction 13 03-16-2010 10:17 AM
Replacing windows with sliding patio door, should I match widths? TomServo Building & Construction 5 09-21-2009 07:22 AM
How to: Measure Patio Sliding doors SunGawd Building & Construction 6 06-09-2009 09:06 PM
