Sidelight Replacement On Front Door. - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-11-2013, 08:44 PM   #1
Rewards Points: 108
Question
Sidelight replacement on front door.
Hey all, I could use some advice. I'm relatively new to home repair.
I'm getting ready to replace my front door. I've already replaced a door on the side of the garage so I am familiar with door replacement, but my trouble with the front door is the sidelight.
My house has brick underneath the sidelight so the sidelight will not be as tall as the door itself, so buying a door with the sidelight next to it is out of the question - because those sidelights are as tall as the door. The sidelight is 5' tall and about 1' or 1.25' wide, and I can't find anywhere that sells separate sidelights, much less a sidelight that is shorter than the full height of a door.
The existing sidelight is kinda ugly, custom built, and single paned so it has a lower R value so I would really like to replace it with something premade if possible.
Can anyone offer some advice? I'll be very thankful to anyone who can steer me in the right direction.
-Jeff
jeffdoesrepairs is offline   Reply With Quote
Old 06-12-2013, 07:11 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,624
Picture is going to really help out a bunch here.
The Following User Says Thank You to Windows on Wash For This Useful Post:
oh'mike (06-12-2013)
Old 06-27-2013, 05:08 PM   #3
Rewards Points: 108
How to get replies?
How do I get replies to my question? Should I repost?
Old 06-27-2013, 05:21 PM   #4
kwikfishron's Avatar
Rewards Points: 586
I moved your thread to "Windows and Doors". You may want to re-size your picture though.
kwikfishron is online now   Reply With Quote
Old 06-27-2013, 07:02 PM   #5
That is not a mulled sidelite and is more likely a single panel entry door with a custom and field made glass panel.
You can pull the door and just put in a new window or convert that single pane section to a double pane by making your own IGU.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
HomeSealed (06-29-2013), jeffdoesrepairs (03-21-2014)
Old 06-27-2013, 07:10 PM   #6
Rewards Points: 13,712
If I had to replace that door I would order it with flat jambs, and install my own PVC brick molding.
Reason being there's gaps at the bottom of the brick molding that should not be there.
Old 06-28-2013, 10:34 PM   #7
Rewards Points: 108
Thanks for the suggestions!
I had to look up IGU - Insulated Glass Units, and you are right, it is a single pane and I assume it was custom built with the house.
So, how do I replace the window with an IGU? I don't know where to find insulated windows that are 5'x1'. You certainly can't buy windows with those dimensions at the Home Depot.
Also, with regards to the brick molding, you are right I think there is a problem there. The entire stoop sunk and I'm not sure it's doing good things to the house. I will worry about that when I get the stoop replaced along with the driveway.
Thanks for any further suggestions.
Old 06-29-2013, 07:46 AM   #8
Any real glass company can order one custom made for you.
It's going to need to be tempered glass since it's near a door.
Is there a crawl space, slab, or basement under the house?
Reason I ask is even if that slab sunk the kick board should not have dropped with it unless there's an issue under the house.
Old 06-29-2013, 09:01 AM   #9
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Good advice above. Essentially you just have a door with a separate window next to it. They can be replaced independently of each other unlike most doors with sidelite(s). Replace just the glass of the window or the whole frame.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Replaced front door, help me fix the alarm sensor Silverlx Electrical 4 02-19-2013 10:11 AM
Front door Replacement streetneons Windows and Doors 24 01-19-2013 09:57 AM
Replacement exterior door bottom vinyl weather stripping Beowing Windows and Doors 3 07-05-2012 04:33 PM
replacement exterior door bubbler Windows and Doors 3 07-05-2012 04:20 PM
Front Door - Door stops? 1655graff Carpentry 6 08-14-2009 12:40 PM
