-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Sidelight replacement on front door. (http://www.diychatroom.com/f104/sidelight-replacement-front-door-181698/)
jeffdoesrepairs 06-11-2013 08:44 PM
Hey all, I could use some advice. I'm relatively new to home repair.
I'm getting ready to replace my front door. I've already replaced a door on the side of the garage so I am familiar with door replacement, but my trouble with the front door is the sidelight.
http://tinypic.com/r/9vijat/5http://i39.tinypic.com/9vijat.jpg
My house has brick underneath the sidelight so the sidelight will not be as tall as the door itself, so buying a door with the sidelight next to it is out of the question - because those sidelights are as tall as the door. The sidelight is 5' tall and about 1' or 1.25' wide, and I can't find anywhere that sells separate sidelights, much less a sidelight that is shorter than the full height of a door.
The existing sidelight is kinda ugly, custom built, and single paned so it has a lower R value so I would really like to replace it with something premade if possible.
Can anyone offer some advice? I'll be very thankful to anyone who can steer me in the right direction.
-Jeff
Windows on Wash 06-12-2013 07:11 AM
Picture is going to really help out a bunch here.
jeffdoesrepairs 06-27-2013 05:08 PM
How to get replies?
How do I get replies to my question? Should I repost?
kwikfishron 06-27-2013 05:21 PM
199 Attachment(s)
I moved your thread to "Windows and Doors". You may want to re-size your picture though.
Windows on Wash 06-27-2013 07:02 PM
That is not a mulled sidelite and is more likely a single panel entry door with a custom and field made glass panel.
You can pull the door and just put in a new window or convert that single pane section to a double pane by making your own IGU.
joecaption 06-27-2013 07:10 PM
If I had to replace that door I would order it with flat jambs, and install my own PVC brick molding.
Reason being there's gaps at the bottom of the brick molding that should not be there.
jeffdoesrepairs 06-28-2013 10:34 PM
Thanks for the suggestions!
I had to look up IGU - Insulated Glass Units, and you are right, it is a single pane and I assume it was custom built with the house.
So, how do I replace the window with an IGU? I don't know where to find insulated windows that are 5'x1'. You certainly can't buy windows with those dimensions at the Home Depot.
Also, with regards to the brick molding, you are right I think there is a problem there. The entire stoop sunk and I'm not sure it's doing good things to the house. I will worry about that when I get the stoop replaced along with the driveway.
Thanks for any further suggestions.
joecaption 06-29-2013 07:46 AM
Any real glass company can order one custom made for you.
It's going to need to be tempered glass since it's near a door.
Is there a crawl space, slab, or basement under the house?
Reason I ask is even if that slab sunk the kick board should not have dropped with it unless there's an issue under the house.
HomeSealed 06-29-2013 09:01 AM
Good advice above. Essentially you just have a door with a separate window next to it. They can be replaced independently of each other unlike most doors with sidelite(s). Replace just the glass of the window or the whole frame.
