Side Door Water Issue - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-26-2014, 05:19 PM   #1
side door water issue
had a new door installed by a friend of a family member last summer.... i tore up my floor for a kitchen reno... and saw that sub floor was wet... ive been tryin to find where its leakin from... i have been caulking it like mad just to try and solve it...but nothing i do stops its..... i have a lot of caulk in there now i know it doesnt look great but its just caulk once i stop the leak ill fix it up nicer... i just dont know what else to do... ill post a few pictures in a minute
thanks
Click4chips is offline   Reply With Quote
Old 04-26-2014, 05:23 PM   #2
Old 04-26-2014, 05:28 PM   #3
could it be there the sills connect ? or would that be unlikely
Old 04-26-2014, 05:39 PM   #4
Rob
Robpo's Avatar
Rewards Points: 826
I would check around molding above door jamb. Just a hunch.
Robpo is offline   Reply With Quote
Old 04-26-2014, 05:42 PM   #5
you mean right at the top where the drip edge is?.... i only threw water at the door
Old 04-26-2014, 06:05 PM   #6
Rewards Points: 6
I could also be the joint where the siding meets the moulding.
Dan
djlandkpl is online now   Reply With Quote
Old 04-26-2014, 06:08 PM   #7
ya its not caulked there im gonna get some... but i didnt put any water there ...
Old 04-26-2014, 06:13 PM   #8
Rewards Points: 6
Maybe it's getting under the door, between the bottom of the door and the threshold.
Dan
Old 04-26-2014, 06:14 PM   #9
i thought that as well but its all dry there i use a paper towel and its dry
Old 04-26-2014, 06:17 PM   #10
Rob
Robpo's Avatar
Rewards Points: 826
Was the saddle/threshold wet? I am thinking maybe you need a drip edge on bottom of door.
never mind
Old 04-26-2014, 06:20 PM   #11
so u mean the brown thing with the screw caps on it?
Old 04-26-2014, 06:21 PM   #12
Rob
Robpo's Avatar
Rewards Points: 826
yes..
Old 04-26-2014, 06:23 PM   #13
i tiny bit about half an inch maybe less, not all the way inside
Old 04-26-2014, 07:08 PM   #14
Rob
Robpo's Avatar
Rewards Points: 826
The more I look at it the bottom pic is a different door then the two above it
Old 04-26-2014, 07:24 PM   #15
no same door
Zoning issue with planned shed Ler0y Jenkins General DIY Discussions 15 02-01-2012 01:41 PM
Westinghouse furnace issue joe8918 HVAC 9 12-04-2011 06:50 PM
Durock installation in bath, what side goes out? smcmurrey Building & Construction 8 12-12-2010 07:48 PM
Ceiling mounted clothes rod (one side wall mount, one side ceiling mount) DCA General DIY Discussions 9 08-17-2009 11:13 AM
