Shower Window Problems - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-21-2011, 12:29 AM   #1
Shower window problems
After taking a shower I see water coming out through the shower window into the siding of the house. Is that normal?
Liliana is offline   Reply With Quote
Old 11-21-2011, 02:56 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
No.
You need to have it look at as long as what you are seeing is not condensation...which it does not sound like it is.
Old 11-30-2011, 07:41 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
better on the siding than into the wall
Tom Struble is offline   Reply With Quote
Old 11-30-2011, 08:33 AM   #4
+1
The only problem with that is that I can bet you a dime to a dozen that if it is getting all the way to the outside surface of the exterior wall, it is being dropped off inside the wall too!
The Following User Says Thank You to Windows on Wash For This Useful Post:
Bud Cline (11-30-2011)
Old 11-30-2011, 03:59 PM   #5
Picture would help tremendously.
Stanchek is offline   Reply With Quote
Old 11-30-2011, 04:54 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...if it is getting all the way to the outside surface of the exterior wall, it is being dropped off inside the wall too!
There should be some kind of a guarantee that goes with that statement because there is a 99% chance water is in the interior wall also.
The Following User Says Thank You to Bud Cline For This Useful Post:
ben's plumbing (11-30-2011)
Old 11-30-2011, 09:35 PM   #7
Originally Posted by Windows on Wash View Post
+1
not necessarily,if it's leaking thru the sash on a welded unit,which is what it sounds like to me
Old 11-30-2011, 09:54 PM   #8
Rewards Points: 13,260
First problum, a window in a shower, never a goood idea.
Now that it's leaking you can be sure it's getting inside the wall and rotting out the wood, the insulation and there's going to mold inside the wall.
Fix, get rid of the window.
Old 11-30-2011, 10:02 PM   #9
C'mon, if a window is done correctly in a shower, you'll never have a problem with it. But yes, the OP is screwed, probably water in the wall. Again, a picture would really help.
Old 12-01-2011, 10:30 AM   #10
Tom...how many windows do you see in showers that are not done properly?
I am just basing my recommendations/hypothesis on my experience.
You certainly can make a window work in a shower and it is entirely possible that Tom's hypothesis is correct that the water is draining through the weep holes in the sash track and dripping to outside.
Water is a persistent and will find the smallest gap. Many bathroom windows that we see are tile up to after installation and in doing so, create a damn effect. That, combined with what is often times an improperly sloped interior sill, usually equates to inside wall leakage.
Tom Struble (12-01-2011)
Old 12-01-2011, 10:50 AM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Good Lord.
If only John Kennedy had suddenly sneezed at the precise moment the trigger was pulled..........
Old 12-01-2011, 10:37 PM   #12
i wasn't arguing with you W.O.W.....well maybe i was just that i think more info is needed
i really appreciate and learn from your post
The Following User Says Thank You to Tom Struble For This Useful Post:
Windows on Wash (12-01-2011)
Old 12-01-2011, 10:42 PM   #13
No worries. I didn't take it as argumentative.
I appreciate the banter from time to time and I think we are all the better for it and better contractors.
New replacement window problems iminaquagmire Windows and Doors 7 11-12-2011 12:56 AM
Problems re-grouting shower tile Bartman72 General DIY Discussions 5 10-22-2011 02:37 PM
Contractor problems, please help. What can I do? techprincesse Off Topic 26 07-23-2010 02:05 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Shower in Window jchri66 Remodeling 1 05-27-2008 01:50 PM
