Shower Window Caulking??? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-15-2013, 10:44 AM   #1
Rewards Points: 145
Shower window caulking???
should i use something like a dap product or a silicone?
wantboost is offline   Reply With Quote
Old 10-15-2013, 11:12 AM   #2
Rewards Points: 14,306
Window in a shower, now that's just a very bad idea.
Use something like Alex 230 if you plan to be able to paint it to match the trim.
Old 10-15-2013, 01:19 PM   #3
Master Plumber
Benplumbing's Avatar
I would agree with the window being a very bad idea. But I think I would check the painting section of this website instead of the plumbing they might give you a better idea as to what you will need / what will last.
Benplumbing is offline   Reply With Quote
Old 10-15-2013, 01:20 PM   #4
Rewards Points: 145
There's just tile around it
Old 10-15-2013, 01:22 PM   #5
Master Plumber
I understand but they deal with all sorts of different applications interior/exterior there going to be able to tell you the best product to use.
Old 10-15-2013, 03:49 PM   #6
K&B Designer
Live_Oak's Avatar
A siliconized acrylic caulk will be paintable and not as difficult to remove and replace when the time comes for that to happen. Unfortunately, there is no permanent solution other than getting rid of the window or rebuilding it completely with a vinyl window and proper waterproofing. Sooner or later, the caulk will fail and water damage will occur. It's not if. It's when.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
jmon (10-15-2013)
Old 10-15-2013, 07:26 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
in my experience the alex brand silicone is garbage,we use higher end silicone thats sold at the lumber yard, not the stuff sold at big box stores.
also if you can manage it i would use pvc trim for the window also and install a blueskin drip pan on both the inside edge and outside edge of the opening to protect the wood sil from water damage in the event of a leak
woodworkbykirk is offline   Reply With Quote
Glass block window in tiled shower stall ddmcc Windows and Doors 16 01-04-2012 10:48 PM
Need window covering for shower window susha8 Interior Decorating 2 05-16-2011 10:42 AM
Shower caulking donjt81 Kitchen & Bath Remodeling 5 11-20-2009 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Shower window issue help! Ducowti Building & Construction 2 05-26-2005 03:36 AM
