Should Foam Be Used When Installing Vinyl Replacement Windows? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-26-2013, 01:50 PM   #1
Rewards Points: 150
Should foam be used when installing vinyl replacement windows?
My house had 6 windows blown out in the May 20th tornado that hit Oklahoma. I'm now contacting contractors to get them replaced. The first guy I talked with said he did not use foam. He said caulking the inside and outside is all that matters.
I have some more contractors lined up to give me an estimate and I would like to know the proper way they should be installed. Based on videos I've watched and from reading some posts here, it sounds like low expansion foam isn't a requirement, but it's recommended.
What other questions should I ask?
ConstantChange is offline   Reply With Quote
Old 06-26-2013, 04:06 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Foam can almost always be used.
If the gap is so tight that you can't get the foam nozzle in there, caulking them tight is just as good.
The Following User Says Thank You to Windows on Wash For This Useful Post:
HomeSealed (06-26-2013)
Old 06-26-2013, 04:41 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I think that your interpretation is spot-on CC, not necessarily required but definitely recommended in most cases. Generally it is the old-timers that are set in their ways that don't like the stuff. These are the same guys that rave about it once they make the switch and get good at using it.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Andersen vs Jeld Wend Replacement Windows ... JasonCA Remodeling 13 03-20-2012 10:46 PM
Sealing Replacement Windows Pittsville Windows and Doors 22 07-15-2011 03:04 PM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 02:24 AM
Vinyl Replacement Window Questions Marty1Mc Windows and Doors 6 05-22-2011 10:36 PM
Vinyl Replacement Windows fixiechick General DIY Discussions 56 04-20-2009 05:37 PM
