Shopping For A Double Door Plus Sidelites - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-02-2011, 07:52 PM   #1
Shopping for a double door plus sidelites
I'm shopping around for a new front door. I'm replacing a double door with 2 sidelites (see picture below). I've looked at steel doors, but they sure seem to ding up fast. And the wood doors seem too expensive. So I'm now looking at fiberglass doors, something that I can stain to a color I like. Any suggestions about what you'd recommend?
proofer is offline   Reply With Quote
Old 04-03-2011, 07:38 AM   #2
kwikfishron's Avatar
Rewards Points: 86
Fiberglass is the way to go. When properly stained you would never know that it wasn’t wood.
I use a lot of Thema-Tru doors they have some real nice stuff.
One thing I do suggest is stay away from the Box Stores on this one. Go to a well established local Lumber Yard. They will have the best selection and customer service.
You will save no money if you order a door from a catalogue at a Box Store.
kwikfishron is online now   Reply With Quote
Old 04-03-2011, 08:26 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
x2...........Therma Tru........
Lumberyard or Door and Window specialty store.
tcleve4911 is offline   Reply With Quote
Old 04-03-2011, 07:32 PM   #4
Thanks for your replies. I'll check out Therma Tru.
Can you tell by looking at my picture if the doors and sidelites are all one unit? The house was built in 1965 if that helps any. I'm wondering if I can just replace the double doors, but keep the old sidelites.
Old 04-03-2011, 07:40 PM   #5
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Depending on your skill level, you certainly can just buy the door slabs and install them into the existing frame.
I was wondering if the glass texture would want to be preserved.
Good choice....I'm guessing that glass would not be available from Therma Tru
Old 04-03-2011, 07:43 PM   #6
Those old doors are steel doors. Would we still be able to use the same old frame but with new fiberglass doors? Would that a problem to do?
Old 04-03-2011, 07:54 PM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
It won't be a problem as long as the door sizes are exactly the same.
If your question is Steel vs Fiberglass. No problem.
Weatherstripping may become an issue depending on how the steel door was detailed to create a tight seal.
Double switch wiring rockclimber Electrical 18 03-18-2012 11:13 PM
Double Hung vs Single Hung CZSteve Remodeling 0 11-08-2010 08:29 AM
double pole breaker + outlets / x10 BlueBSH Electrical 0 09-09-2010 01:44 PM
Eliminating Double Taps in Older Sylvania 200A Panel Reilley Electrical 14 01-11-2009 05:52 PM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 03:44 PM
