Shed Door (-roll Up?) - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-19-2014, 11:39 AM   #1
MarginallyQualified
Rewards Points: 2,464
shed door (-roll up?)
As if I didn't already have enough going on somehow or other I've managed to tear down the old slap dash (lean to & filled in walls) shed, expand the base area (24 x12 now), set a course of block and just this morning truck a load of lumber over.
The question is how best to do a door.
The RO lays out to 72" between the blocks which could be done with a simplish split of hinged something or other (36&36 maybe 42&30)... or maybe a single roll up could be found that would sort of match or at least blend in with the rest of the structure and the existing OH door on the garage.
Any ideas of what companies to look for?
Material choices? Prices?
shed door (-roll up?)-gar-shed2011.jpg   shed door (-roll up?)-shednewfound.jpg
Old 06-19-2014, 12:35 PM   #2
Rewards Points: 144
You could make a double swing in door to fit or you could buy a roll up door like they use on storage buildings.Lots more options available.
mako1 is offline   Reply With Quote
Old 06-19-2014, 01:07 PM   #3
MarginallyQualified
Originally Posted by mako1 View Post
You could make a double swing in door to fit...
like split the width even at 36 & 36? or maybe offset at 42 & 30?
...or you could buy a roll up door...
yep.
Old 06-20-2014, 06:47 AM   #4
MarginallyQualified
bump.
No one has put a roll up door on a shed?
No one has looked into it and learned some wisdom they can share?
Old 11-25-2014, 09:50 PM   #5
Rewards Points: 892
Originally Posted by TarheelTerp View Post
bump.
Did you get some answers? I'm in the same position. Looking for a 8x7 roll up. Youtube has a good installation video with a guy doing a 'how-to-build-a-shed' video.
Daugela is offline   Reply With Quote
Old 11-27-2014, 05:32 PM   #6
Rewards Points: 14
I looked at this idea ("small" roll-up door) years back. My idea was to use the same hardware that is used in some semi-tractor rigs and rental storage units. I was working on a storage shed that I built against an outside wall of concrete blocks. The thing that stopped me was the pri$e. You may find what you're looking for in Farmtek's catalog.
ChuckTin is online now   Reply With Quote
Old 11-27-2014, 11:44 PM   #7
Rewards Points: 892
I found them to be cheaper than regualr garage doors!!! Prices have come down. Many online warehouses with cheap prices.
I ordered one this week. $450 for an insulated commerical grade.
Old 11-28-2014, 05:50 AM   #8
MarginallyQualified
That's about what I found as well ...but I view $450 cost differently.
With a bit of care/planning the t-111 cut for the 6' x7' opening become
the doors. Those, along with a couple of 2x4's and some hardware...
and all is done for about $50?. I'm happy.
Old 11-28-2014, 08:04 AM   #9
Rewards Points: 892
Looks great! Yeah, $450 is getting up there, but for a new roll up, it's not too bad. Non-insulated was $297.
The Following User Says Thank You to Daugela For This Useful Post:
TarheelTerp (11-28-2014)
Old 11-28-2014, 09:35 AM   #10
Rewards Points: 236
that looks nice, man
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Old 11-28-2014, 03:01 PM   #11
r0ckstarr's Avatar
Rewards Points: 2,060
Yeah, that looks great.
r0ckstarr is offline   Reply With Quote
The Following User Says Thank You to r0ckstarr For This Useful Post:
Old 11-28-2014, 03:49 PM   #12
MarginallyQualified
Since that picture was taken (the next day I suspect)
the rest of the block was painted the same brown as the trim too.
Based on how happy I am with the Behr concrete epoxy I'll be doing the
garage floor next spring and if I know me... the concrete apron as well.
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Zoning issue with planned shed Ler0y Jenkins General DIY Discussions 15 02-01-2012 12:41 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
