Self Closing Doors Between House And Garage? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-11-2014, 12:35 PM   #1
Rewards Points: 980
Self closing doors between house and garage?
Someone told me that code requires a self closing door between the house and the garage.
I have two spring loaded hinges there, but apparently the hinges are not loaded and don't do anything.
So, is that a code requirement?
If so, do they have to be loaded?
And if so, can I leave them the way they are and load them when I sell the house?
I bought the house 2 years ago, and no one seems to have noticed the problem then.
In 30 years of home ownership I am pretty sure I have never failed to close the garage door; the odds of the first time being the same time as a garage fire are rather too high to worry about. On the other hand, I frequently need both hands to carry stuff in.
Toller is offline   Reply With Quote
Old 04-11-2014, 02:02 PM   #2
47_47's Avatar
Rewards Points: 58
Need a self closing fire rated door between house and attached garage. Should be flagged on resale or major permitted / inspected improvements to either area. Your house do what you want.
47_47 is offline   Reply With Quote
Old 04-11-2014, 02:57 PM   #3
Oso954's Avatar
Rewards Points: 1,126
You can always check with the AHJ.
In my subdivision, the homes were built before the self-closing fire rated door requirement was adopted. In our area, the doors (non fire rated) are considered to be grandfathered.
Oso954 is online now   Reply With Quote
Old 04-11-2014, 04:40 PM   #4
Registered User
Rewards Points: 5,516
I agree, check locally. The self-closer clause was dropped for the 2003 IRC, I believe. Depends on local amendments to the code....
Gary
Old 04-11-2014, 05:02 PM   #5
Rewards Points: 6,652
To add to Gary's post. Too many hands and fingers were getting pinched when the door closed. That is why it is no longer required.
Old 04-11-2014, 05:09 PM   #6
Rewards Points: 13,750
No one knows where you are since there's no location in your profile.
Never heard of such a thing in residential building.
Fire rated door yes, self closing no.
Old 04-11-2014, 07:05 PM   #7
firehawkmph's Avatar
Rewards Points: 1,884
Around here in northeast Ohio it was code when I was building house in the 90's and early 2000's. Not sure now but whenever I replace that particular door, I still order them with self closing hinges. Never pinched my fingers in them. Not that big a deal to get used to. And when you are ordering the doors from a real lumberyard, the s/c hinges don't cost that much.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-11-2014, 09:44 PM   #8
Rewards Points: 960
It is a good idea, easy to understand. Not only do you need a fire door, but it needs to be closed. And it doesn't need to be closed just because of a fire, it needs to keep exhaust fumes out of the house as well.
I saw the aftermath of a fire in an attached garage without sheetrock on the attic portion of the party wall, and the people who were in the house just had time to stand up and run out of the house.
If you don't like the idea of a self-closing door or a fire wall, then have a detached garage and you can burn it down as often as you like.
cleveman is offline   Reply With Quote
Old 04-11-2014, 09:48 PM   #9
Originally Posted by joecaption View Post
No one knows where you are since there's no location in your profile. Never heard of such a thing in residential building.
Really common during the early Millennium.
The hospital my mother was in. Which is the one that my wife & I always end up for surgeries. They have removed the hydraulic closer's from all of the rooms. Too many pinched & injured hands & fingers.
Old 04-12-2014, 07:28 AM   #10
I say leave them in, Darwin's theory at work.
Mike Hawkins
Old 04-12-2014, 12:15 PM   #11
Not when you do not want to pay the Medical bills Mike.
Old 04-12-2014, 12:54 PM   #12
Oso954's Avatar
Not having a complete fire wall and the issue of a fire rated door in that wall are two different issues. If you live in a town/city with a decent fire dept response time, the fire isn't going to burn thru a solid wood door before the FD gets the there. Probably won't burn thru a hollow core one either.
Living in a rural area with longer response times ups the desirability of the fire rated door.
Old 04-12-2014, 02:05 PM   #13
Plumber
TheEplumber's Avatar
Rewards Points: 682
Still a requirement in my area
IMO pointless if the firewall does no exist.
Most smart people don't do it without opening the garage door but I would think a fair amount of exhaust fumes could enter a home as well....
Old 04-14-2014, 01:37 PM   #14
Mold!! Let's kill it!
Rewards Points: 2,012
It certainly depends on what code was in force at the time of construction. If it has spring hinges, then they were probably required. Wind them up to put tension on them however you see fit.
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 10:20 AM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 07:54 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
New detached garage with sub and ground, house has no ground at panel italie Electrical 9 09-12-2011 02:43 PM
Carriage House Steel Garage Doors Rock8Reno Windows and Doors 3 05-13-2011 08:25 AM
