Secure-minded Garage Man-door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-05-2013, 01:53 PM   #1
Dave88LX's Avatar
Rewards Points: 564
Secure-minded garage man-door
I have a man door in my detached garage that I need to replace. The door is beat to hell, the frame is all busted. Looking to get a pre-hung door to install. Framing is 2x4 stud, vinyl siding.
Is steel the best option for security in an entry door? Lowes/Home Depot has some steel doors but I can't tell from the website the metal gauge, and I don't think they're really even "security" oriented anyways. Perhaps I should be looking elsewhere for this, maybe not though.
Any recommendations on what I should be looking to install? I guess a steel-framed door would be the best option. At least steel-reinforced wooden frame in the striker/latch area. But, I really don't know.
Eh.
Picture that is too far away with no detail and won't help you at all:
Dave88LX is offline   Reply With Quote
Old 11-05-2013, 02:40 PM   #2
Rewards Points: 13,296
Any prehung steel door with a dead bolt will work.
If they still want to come in they can just break the window and unlock it.
Old 11-05-2013, 06:17 PM   #3
Remodeler
Rewards Points: 316
You can buy a true security door, but get out your wallet cause they aren't cheap. A regular steel entry door can be substantially beefed up a lot cheaper. You are probably not going to stop a truly determined thief but you can slow them down and make them create a lot of noise trying to get in. They may decide to just move on to an easier target.
This YouTube video has some good ideas for beefing the strike up with a mending plate, this along with a good quality deadbolt and a few long screws driven through the hinges and into framing can dramatically beef up a plain old home center door.
While you are at it don't forget about the overhead door. A thief can fish a piece of wire up through between the overhead door and jamb, snag the emergency rope and trip the garage door. It takes about as long to do it as it did to type this. I removed the emergency release rope on my shop door and wired the trolley latch so it can't be tripped. Windows in the garage door make this even quicker and easier.
With my shop a few blocks away at another property; I have the same worries. I have done some of these things plus am adding some bars to the inside of the windows to stop entry if they break the windows. I do not live in a particularly high crime area, but drug problems have created a lot more thieves around here these days . These few measures coupled with a couple dusk to dawn lights will hopefully keep my stuff mine.
iamrfixit is offline   Reply With Quote
garage door won't go down Kela82 Building & Construction 7 02-21-2013 12:16 AM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-26-2011 12:58 AM
Garage Door Question javan Building & Construction 4 04-25-2011 07:52 AM
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 09:19 AM
Garage Door Extension Spring Question kmc143 Building & Construction 4 02-23-2010 09:24 AM
