Sealing Replacement Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-14-2015, 10:30 PM   #1
DIYer
Rewards Points: 262
I'm installing vinyl double hung, double pane replacement windows in my 1965 house's garage to replace the original (as far as I can tell) wood single pane windows. I will eventually do all the windows but decided to start in the garage as a test since this is my first window install and the walls are open. I've framed the walls and there is no interior trim, stool, etc.
I'm a little confused by the terminology and all the sealants recommended. Please confirm/correct my steps.
1. Remove old window from inside (no trim present) and clean opening.
2. Test fit window in opening.
3. Seal inside edge of blind stop with OSI Quad on both sides and top of opening.
4. Install header expander with bead of OSI Quad on top of window (or skip it depending on who you ask).
5. Press window into place. Have assistant hold it while you verify it is level and centered and then shim as needed.
6. Screw four supplied screws through pre-drilled holes into frame.
7. Check work and verify window is still centered and level.
8. Seal bottom of window with daptex expanding foam and then trim and install sill angle to outside bottom.
9. Install GE clear silicone on inside of window to wood frame gaps OR use daptex for this??? It was mentioned to silicone the inside of the blindstops but I can't get to the blindstops once the window is in, just this gap.
10. Caulk outside edges between new window and old blind stops as well as the sill angle with exterior paintable caulk Dap Alex Fast Dry. Leave a weep gap or drill weep holes or don't.
thanks!
mystic_cobra is offline   Reply With Quote
Old 05-15-2015, 06:07 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,276
thanks!
Call/email me if you want to. I can swing by next week and show you what to do.
Old 05-15-2015, 08:09 AM   #3
DIYer
Rewards Points: 262
Thanks for relocating my thread. I feel a little bad about hijacking but thought the relevance was...relevant.
WoW-
I really appreciate the offer. Maybe we can sync up next week.
Old 05-15-2015, 04:45 PM   #4
You have my numbers. Give me a shout and I will swing by and show you best practices.
DYI Replacement Windows Uncle Dave Windows and Doors 2 02-21-2013 07:44 AM
Replacement windows StanDavid Building & Construction 8 03-13-2011 03:37 PM
Replacement windows not going to work? AnthraciteDude Building & Construction 9 12-10-2010 11:43 PM
Measuring for replacement windows. adeebdiy Carpentry 5 10-17-2010 09:07 PM
