Sealing Replacement Windows - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-10-2011, 09:00 AM   #16
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
I use Windex and a smooth rag...........
tcleve4911 is offline   Reply With Quote
Old 07-11-2011, 07:09 AM   #17
Maryland
Lots of great ideas, thanks a million! I'm making up some "test corners" out of 1x scraps to try out the different techniques and see what works best for me. Practice will hopefully make perfect.
Pittsville is offline   Reply With Quote
Old 07-12-2011, 07:37 AM   #18
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Good idea... Lastly, I'd recommend buying yourself a halfway decent caulk gun, and don't be afraid to pick up some speed as you lay the bead. The key is matching the pressure that you are squeezing with the speed that you move the gun. If you try to be too careful and go to slow, you'll have no chance. That is the #1 mistake that I see.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 07-12-2011, 04:30 PM   #19
Custom Home Builder
Originally Posted by kwikfishron View Post
Saliva does work the best but after the first lick I prefer the spit technique over licking my fingers.
So you prefer to spit....
thomasjmarino is offline   Reply With Quote
Old 07-12-2011, 05:03 PM   #20
kwikfishron's Avatar
Rewards Points: 90
Iíd rather spit on my finger than lick it, thatís some nasty tasting stuff and that flavor lingers around for quite awhile too.
kwikfishron is offline   Reply With Quote
Old 07-13-2011, 07:59 PM   #21
Home Performance
HomeSealed's Avatar
Rewards Points: 710
If you lube it up well enough the first time, it won't stick to your finger at all... I have to say, I've never gotten the taste of quad in my mouth, although I'm sure its been a healthy cocktail of lead dust and all the delicious carcinogens in the caulk.
www.HomeSealed.com
Old 07-14-2011, 02:10 PM   #22
Rewards Points: 459
Went to a training show for my work a couple years back. Had a demo from an OSI rep.
Recommendation was alcohol wipe prep and a soap mixture for sweeping. We use a non-surfactant detergent (Dreft or Ivory Snow baby laundry det) in a spray bottle. Mist over bead or onto fingers. Works nice .
And definitely, without a doubt, OSI Quad is the way to go.
Nick DIY is offline   Reply With Quote
The Following User Says Thank You to Nick DIY For This Useful Post:
HomeSealed (07-16-2011)
Old 07-15-2011, 04:04 PM   #23
Maryland
What ratio of soap to water do you use?
Blind Problems With Replacement Windows (Long) JohnnyLargo Windows and Doors 9 04-30-2011 10:46 AM
Replacement windows StanDavid Building & Construction 8 03-13-2011 04:37 PM
Replacement windows not going to work? AnthraciteDude Building & Construction 9 12-11-2010 12:43 AM
Measuring for replacement windows. adeebdiy Carpentry 5 10-17-2010 10:07 PM
Need recommendations for replacement windows magnolia Building & Construction 10 06-25-2009 10:44 PM
