Screws That Hold Door Hinge To Frame Are Loose - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-31-2013, 11:29 AM   #1
Rewards Points: 62
Screws that hold door hinge to frame are loose
I have a door that has came loose on the top hinge and the screws are not staying in. What is the best way to fix this?
mclld is offline   Reply With Quote
Old 07-31-2013, 11:45 AM   #2
Rewards Points: 14,312
Install longer screws, 2-1/2" will work.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
HomeSealed (07-31-2013), mclld (07-31-2013)
Old 07-31-2013, 11:58 AM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Yup. 9 times out of 10 longer screws will take care of it.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
mclld (07-31-2013)
Old 07-31-2013, 11:59 AM   #4
Rewards Points: 62
thanks
If that will not do the trick then what would be the next suggestion?
Old 07-31-2013, 01:39 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Is it loose on the slab side or the hinge side? Solid or hollow core door?
www.HomeSealed.com
Old 07-31-2013, 01:41 PM   #6
Rewards Points: 62
loose on the door frame of the house and the door is solid
Old 07-31-2013, 02:39 PM   #7
MT Stringer's Avatar
Rewards Points: 254
Drill out the screw hole and glue in a hardwood dowel. Then pre drill and install your screws (after the glue has had time to dry.) Worked for me. A 1/4 inch hole and a short piece of wooden dowel for each hole should be all you need.
MT Stringer is offline   Reply With Quote
Old 07-31-2013, 02:43 PM   #8
Rewards Points: 62
I dont have a drill
Old 07-31-2013, 03:42 PM   #9
Rewards Points: 254
Originally Posted by mclld View Post
I dont have a drill
Well, if you want to solve your problem, fork over the cash. Drills are cheap these days. Add a cheap drill bit set and buy a dowel rod and some glue and before you know it, you will be calling yourself a handyman!
Old 07-31-2013, 03:56 PM   #10
Rewards Points: 2,648
Filling the hole with wooden toothpicks and some wood glue will work also.
SPS-1 is offline   Reply With Quote
Old 07-31-2013, 05:12 PM   #11
Home Performance
HomeSealed's Avatar
Rewards Points: 712
The above methods are optional as well, however I still prefer a longer screw from the get-go. Being on the frame side of the hinge, a longer screw WILL work, as you'll go through the stripped hole in the frame and anchor it right into the RO (2x4 or whatever is there). We generally do this with one or two screws in each hinge in new door installs these days.
www.HomeSealed.com
oh'mike (07-31-2013)
Old 07-31-2013, 05:25 PM   #12
kwikfishron's Avatar
Rewards Points: 1,008
As mentioned install a longer screw or two. If that screw doesn't grab (because it's been before) then go with the drill, glue and plug options.
kwikfishron is offline   Reply With Quote
Old 08-01-2013, 02:21 PM   #13
Use a golf tee to fill the hole and screw the screw back in.
Wildsmith is offline   Reply With Quote
Old 08-01-2013, 03:31 PM   #14
Haverhill Trade 1965
The screws probably pulled out because all the weight of the door pulls on that hinge, (it pushes on the bottom one). Longer screws, possibly a size larger, are best. If it pulled out long screws, filling the hole is the only option. A wood Starbucks coffee stirrer split into toothpick size strips do a good job if toothpicks are too short. Since screws in a hinge are usually staggered, your screws should be in the holes farthest from the casing. Drywall doesn't hold screws very well, and the outside screws are very close to it.
Duckweather is offline   Reply With Quote
Old 04-08-2014, 12:13 PM   #15
Rewards Points: 62
I used longer screws but now it is loose again. I went to Lowes and Home Depot and they didnt have any screws longer or wider than what I am currently using(3x5/16). I guess I will try the toothpick tip
Loose sheet metal screws harrysanders Building & Construction 4 05-30-2010 08:16 PM
Metal Front Door with screws that keep coming loose MicheleWilliams General DIY Discussions 7 12-27-2008 09:59 PM
underlayment for stick on tiles or vinyl novice40 Flooring 7 09-03-2008 04:49 PM
screws coming loose Baffeled Building & Construction 4 08-13-2008 08:48 AM
help, loose door hinges screws clyde Carpentry 13 12-19-2007 01:31 PM
