Old 09-25-2014, 10:10 PM   #1
Rewards Points: 346
Screened in Porch Screen Material?
I just moved into a home that has a screened in porch. I need to replace some of the mesh screens due to some holes that are currently in the screens. What is the recommended material to use for this that is strong and durable? I am not sure the material that is on the porch now.
The current screens are stapled on trim pieces of wood around the edges of the openings of the porch. What tips do you have on the best way to install the new screen mesh so they will be tight all of the way around?
kennykenny is offline   Reply With Quote
Old 09-25-2014, 11:16 PM   #2
Rewards Points: 1,062
I suggest the metal screening, as the nylon/ fiberglass / other cloth materials are easily torn and ripped by CATS, and also degrade in the U V radiation.
As for a tight fit, I would build them in a removable framing, and fasten this frame to the existing posts, and cross bars.
Removable for easy cleaning, and replacement if they are ever damaged.
ED
de-nagorg is offline   Reply With Quote
Old 09-26-2014, 03:52 AM   #3
pmd
Rewards Points: 4
I would use fiberglass screen and recommend the brands Phifer or New York wire. Also you need to get Patio/Pool screen from them. Those brands are made for pool enclosures and screen rooms, it is thicker than "window" screen.
You should use aluminum extrusion that is made for screen. Alcoa extrudes this type of aluminum, it contains a spline grove to accept the spline to tighten the screen panel. If you practice rolling screen into the grove you can learn how to tighten properly and avoid bubbles and loose spots in your screen.
Look at attached picture.
pmd is offline   Reply With Quote
Old 09-26-2014, 05:43 AM   #4
Davejss's Avatar
Rewards Points: 334
I prefer aluminum. In my experience aluminum tends to hold up better than the alternatives.
Davejss is offline   Reply With Quote
Old 09-26-2014, 07:04 AM   #5
Rewards Points: 4,152
I use Screen Tight.
http://www.screentight.com/
No more wooden strips to break every time the screen needs replacing.
Any Lowes or Home Depot has it in white, gray and brown.
I also only use what's called pet screen.
It's worked fine for me even on bay side high wind areas.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
de-nagorg (09-26-2014), oh'mike (09-26-2014)
Old 09-26-2014, 08:52 AM   #6
DIY staff
Rewards Points: 2,848
Another vote for 'pet screen'--tough stuff----
Old 09-30-2014, 03:27 AM   #7
Rewards Points: 6
I would use dee why glass which are extremely beautiful and also have a good acoustics.
maryepstein is offline   Reply With Quote
Adding to Concrete Porch + Steps? 99altrade Building & Construction 8 08-01-2011 01:14 PM
Where to buy TruScene-type screen material? NateHanson General DIY Discussions 18 03-26-2011 10:12 PM
Replacing Deck Boards on Screened in Porch kendoit Building & Construction 11 06-09-2010 04:20 AM
Ceiling Material for screened in porch GalFriday Building & Construction 2 06-14-2009 10:49 AM
Free-Standing Deck with Screened Porch Tied into existing Roof butlerbach Carpentry 2 05-14-2009 08:25 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
