Screen Won't Come Off - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-09-2014, 03:48 PM   #1
Rewards Points: 208
i have to repair a broken window screen, but i have no idea how the frame comes off the window. help?
Scully is offline   Reply With Quote
Old 05-09-2014, 04:38 PM   #2
Rewards Points: 2,652
Pull up on the black handle and the screen will slide up a little so you can then push out the bottom and remove it. The top is probably got some dirt in it and is tight, so after pulling a little on the black handle, it may be helpful to use a screwdriver near the corners to lever the screen up. Don't rest the screwdriver on anything delicate when you use it as a lever.
SPS-1 is offline   Reply With Quote
Old 05-09-2014, 05:39 PM   #3
Rewards Points: 14,312
At one time there was two of those plastic tabs to pull up on. One broke off as they all will at some time.
SPS has the right idea.
Old 05-09-2014, 08:36 PM   #4
Rewards Points: 167
Some of my window screens have both tabs, some don't. Those plastic tabs get brittle over time. Even with both tabs intact, I find it easier to remove the screen by placing my fingers up against the top of the Aluminum screen frame and pushing up.
If that's a double hush sash window, both sashes have to be swung out. Once you partially push up the screen frame, you can pull it out completely from the top.
Druidia is offline   Reply With Quote
Old 05-10-2014, 04:23 PM   #5
Rewards Points: 208
i broke a metal latch piece on the end of the center bar of the screen frame. where can i find a replacement latch piece?
Old 05-11-2014, 10:58 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
Call a local glass shop. They usually have the parts and pieces to remake standard screens.
Old 05-11-2014, 07:14 PM   #7
Tom Struble's Avatar
Rewards Points: 2,002
is it a full or 1/2 screen? most 1/2 screens push to the side to remove
ah too late..already did it i see..
Tom Struble is offline   Reply With Quote
Old 05-11-2014, 09:04 PM   #8
Rewards Points: 208
tom, it's a full screen. buy no-see-ums screen by new york at menards. i thought it would be too dark with the tighter mesh, but it's almost clear.
77/78 in screen door and heigh adjustment daluu Windows and Doors 5 03-31-2014 06:31 PM
aluminum or vinyl screen door Startingover Windows and Doors 4 10-14-2013 06:25 AM
Screen Door Dilemma RustyRealtor Windows and Doors 4 08-22-2013 09:06 PM
Best Home Theatre Screen Choice scott t Home Theater 8 03-18-2013 09:18 PM
Wood framed metal screen door 2jakes Windows and Doors 1 11-02-2012 09:32 PM
