-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Screen Won't Come Off (http://www.diychatroom.com/f104/screen-wont-come-off-200543/)
Scully 05-09-2014 03:48 PM
i have to repair a broken window screen, but i have no idea how the frame comes off the window. help?
http://i59.tinypic.com/23uq4as.jpg
http://i61.tinypic.com/2l91929.jpg
SPS-1 05-09-2014 04:38 PM
Pull up on the black handle and the screen will slide up a little so you can then push out the bottom and remove it. The top is probably got some dirt in it and is tight, so after pulling a little on the black handle, it may be helpful to use a screwdriver near the corners to lever the screen up. Don't rest the screwdriver on anything delicate when you use it as a lever.
joecaption 05-09-2014 05:39 PM
At one time there was two of those plastic tabs to pull up on. One broke off as they all will at some time.
SPS has the right idea.
Druidia 05-09-2014 08:36 PM
Some of my window screens have both tabs, some don't. Those plastic tabs get brittle over time. Even with both tabs intact, I find it easier to remove the screen by placing my fingers up against the top of the Aluminum screen frame and pushing up.
If that's a double hush sash window, both sashes have to be swung out. Once you partially push up the screen frame, you can pull it out completely from the top.
Scully 05-10-2014 04:23 PM
i broke a metal latch piece on the end of the center bar of the screen frame. where can i find a replacement latch piece?
http://i61.tinypic.com/iwkylz.jpg
Windows on Wash 05-11-2014 10:58 AM
Call a local glass shop. They usually have the parts and pieces to remake standard screens.
Tom Struble 05-11-2014 07:14 PM
is it a full or 1/2 screen? most 1/2 screens push to the side to remove
ah too late..already did it i see..
Scully 05-11-2014 09:04 PM
tom, it's a full screen. buy no-see-ums screen by new york at menards. i thought it would be too dark with the tighter mesh, but it's almost clear.
