Screen Door Won't Close All The Way - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-07-2013, 12:20 PM   #1
Rewards Points: 137
Screen door won't close all the way
The screen/storm door for our front door has stopped closing completely. We have to remember to pull it the rest of the way closed. I'm wondering what might be causing that.
Another problem I'm having with that door concerns the window. The door has two windows that slide up and down in a track. During the winter when the screen is removed, one window is slid up to cover the top half of the space while one window stays at the bottom to cover the bottom half of the space. In the summer, both windows stay at the bottom when the screen is in place. There is a plastic piece at each side of the top of the windows that holds the window in its track. One of those pieces has broken off, so the top left corner of that window leans out. I'm holding it in place with a piece of scotch tape, but my wife says that looks tacky. She's right, of course. How might I go about fixing this?
Thanks for any assistance.
bucksone is offline   Reply With Quote
Old 08-07-2013, 01:18 PM   #2
Rewards Points: 14,306
Check to make sure the piston rod is not bend from someone opening the door to far or because no one installed the needed safety chain on the door.
Going to have to remove the window and pull apart to replace the whole outside corner.
There's dozens of different style it could be. Any glass company can fix it.
Screen door...Where to get it? eric s General DIY Discussions 6 04-13-2016 07:03 AM
Tiling a patio that already has screen enclosure. gggonzalez Flooring 4 07-05-2014 10:24 AM
Sewer ejector close to main stack vladens Plumbing 4 04-15-2013 09:52 AM
Screen door makeover needed nanaimomuffin Painting 0 06-20-2011 02:25 PM
In-swing non-crank casement window screen blee Windows and Doors 2 05-21-2011 02:42 PM
