Screen Door Slamming Fix - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-29-2012, 09:01 PM   #1
screen door slamming fix
since the cold weather snap my screen door slams shut, i have adjusted the screw and nothing, it is almost as if there is no air getting in the closer/pumpthing, i want to know if i need to replace the entire piece or is there something else I can do to stop my door from slamming. I am afraid the next cold snap might break the glass in the screen door and also afraid that after every cold snap I have to replace the closer. Any assistance would be appreciated. Thankyou
mjneedshelp is offline   Reply With Quote
Old 01-29-2012, 09:08 PM   #2
Rewards Points: 13,694
They wear out, if the screws not adjusting it then it's shot, there is no fixing it.
Look at the piston rod, is it bent? If it is most often it's because there's no safety spring at the top of the door to stop it from swinging open to far. Once the shafts bent it will wear out the seals.
mjneedshelp (01-29-2012)
Old 01-29-2012, 10:32 PM   #3
Thank you so much Joe, I will just replace it, I appreciate your help
Old 01-30-2012, 06:55 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,606
Just started happening with the cold weather?
Tiling a patio that already has screen enclosure. gggonzalez Flooring 4 07-05-2014 10:24 AM
Screen Door push bar.. sick of replacing the full view screen? jarheadoo7 General DIY Discussions 4 12-05-2011 11:14 AM
Small bugs and spiders getting past roll-down screen operagost Windows and Doors 1 07-25-2011 06:52 AM
Screen and Recoat correct way to go? pktrocket85 Flooring 4 03-19-2011 01:49 PM
Shower Screen tomperkins Plumbing 4 12-05-2010 07:22 PM
