Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 06-14-2011, 08:58 AM   #1
screen door hinge busted!
hi. excellent forum here. the top hinge (if that's what it's called) that attaches my back screen door to the frame of the door has come apart. check out the pics. the first time it happened i put a couple new rivets in there but after a while they just busted out of the metal and now the metal holes are all torn up. so, i can't put more rivets in the torn holes. the hinge thing can't be moved either or i would just drill holes in a new spot. any ideas on how to fix this or do i need a new door? thanks!
screen door hinge busted!-door-3.jpg   screen door hinge busted!-door-2.jpg   screen door hinge busted!-door-1.jpg
liverlipsyyz is offline   Reply With Quote
Old 06-14-2011, 09:47 AM   #2
I'd cut a slot through the side and insert a thin piece of sheet metal as a backer. Drill it out and re-rivet.
Nick DIY is offline   Reply With Quote
Old 06-15-2011, 07:42 PM   #3
Household Handyman
First you need to figure out why this keeps happening. Something is causing stress in this area to pull out those rivets. Maybe the screen door frame is swinging too far open and causing this to pull out.
In-swing non-crank casement window screen blee Windows and Doors 2 05-21-2011 03:42 PM
Screen and Recoat correct way to go? pktrocket85 Flooring 4 03-19-2011 02:49 PM
Tiling a patio that already has screen enclosure. gggonzalez Flooring 2 05-02-2010 11:25 AM
replacing screen material on storm door gquayle General Discussion 2 01-25-2010 08:26 PM
Is screen measured like lumber? DIYtestdummy General Discussion 4 07-20-2009 04:07 PM
