-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Saw blade for hollow core 6 panel doors (http://www.diychatroom.com/f104/saw-blade-hollow-core-6-panel-doors-132116/)
bryanp22 01-31-2012 03:01 PM
Need to trim around and inch from the bottom of a hollow core slab door with a circular saw. It's one of those primed six panel doors. Would I want a 40 or 60 tooth saw blade?
Xygris 01-31-2012 03:44 PM
40 tpi
I would use the 40 TPI blade assuming its a molded Masonite door. The 60 TPI blade may not remove enough material from a door that is probably 1-3/8" thick with a solid wood filler on the bottom and I wouldn't be concerned about the appearance on the bottom of a door. Make sure you use painters tape to avoid leaving scuff marks and to prevent chip out.
What I would be even more concerned about is structurally weakening the door by removing too much of the filler strip at the bottom. You may need to find some 1" or 1-1/4" thick stock to glue and clamp into the cavity at the bottom of the door if you are left with little or no filler.
titanoman 01-31-2012 07:31 PM
You just peel the masonite off the scrap and stick the filler back in with some eagle-grip.
ratherbefishing 02-05-2012 11:44 PM
If the door has a luan skin, score the cut line with a utility knife before you cut. It'll decrease chipping.
joecaption 02-05-2012 11:54 PM
Why do you need that much taken off?
I use a plywood blade, Score the line with a utility knife on the top side use blue tape on the sole of the saw and along the line.
