Rust On Door Closer - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-04-2013, 02:06 PM   #1
Rewards Points: 396
Rust on door closer
In winter I keep getting some rust on the storm door closing mechanism. Anyone have any suggestions on preventing that? I realize its due to condensation/moisture.
detroittigerfan is offline   Reply With Quote
Old 11-04-2013, 02:09 PM   #2
Rewards Points: 13,300
Replace it.
Old 11-04-2013, 04:03 PM   #3
Rewards Points: 396
Originally Posted by joecaption View Post
Replace it.
I can't afford to. Do you have any other suggestions? Put some Polyurethane on the closer to protect it. Obviously air in the house is leaking past the main door and getting trapped between storm and regular door. I can't seal it anymore than it is. The main door needs replacing but I just don't have the money.
Old 11-04-2013, 04:16 PM   #4
kwikfishron's Avatar
Rewards Points: 186
A new closure is only ten bucks.
kwikfishron is online now   Reply With Quote
Old 11-04-2013, 04:35 PM   #5
Rewards Points: 396
I know that but a new closer is also metal and its going to rust again. I'm trying to prevent it in the first place.
Old 11-04-2013, 04:53 PM   #6
When you don't have $10.00 it may as well be $100.00.
Clean it off with steel wool or scotch bright, fine sand paper. Place some Vaseline or such on it. It can't hurt.
Hardway is offline   Reply With Quote
Steel studs rust basement help bergerdude Building & Construction 17 10-02-2013 02:24 AM
Rust converter (phosphoric acid) not working Studly Automotive Repairs 3 05-02-2013 07:57 PM
I-Beam, Rust & Concrete kinghong1970 Concrete, Stone & Masonry 13 03-29-2013 12:59 PM
Seeking advice on severe rust buildup issue. YerDugliness Plumbing 2 05-07-2010 07:02 AM
bathroom sink rust removal? bofusmosby Plumbing 4 11-12-2008 07:28 PM
