Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 03-21-2012, 01:43 PM   #1
Rough Opening for French Doors
Hello
I am in the process of completing the rough opening for French Doors. Sorry if this is a silly question but I really want to make sure I complete this correctly. Doing research, I am suppose to make the rough opening 2 inches larger than the width needed for the doors so I can use shims to balance the doors. Below are 2 links for French doors I can purchase at my local Lowes / Home Depot. One door is 61-1/2 inch wide and the other is 60 inch. Are these the dimensions I should use as the needed width? So I either need to make the rough opening 63-1/2 wide or 62 inch wide depending on the door I choose?
Thanks in advance for the feedback.
http://www.lowes.com/pd_10765-77999-...3D1&facetInfo=
http://www.homedepot.com/Doors-Windo...&storeId=10051
VikingDinKC is offline   Reply With Quote
Old 03-21-2012, 02:37 PM   #2
I never trust the internet. Go into the store and measure the door yourself.
psilva8 is offline   Reply With Quote
Old 03-21-2012, 02:46 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As stated, don't trust the information online.
We prefer to have any doors onsite prior to starting renovations and/or framing construction, to ensure that the RO measurements are created accurately.
If you can't get the doors first and have them there, then (as also recommended) go to the store and do your checking.
- Build Well -
Old 03-21-2012, 05:26 PM   #4
Thanks for the feedback. I will measure the doors. My guess is Lowes and Home Depot sell the same doors for quite a while.
Widening existing laundry area door opening DavidH Remodeling 4 02-21-2012 04:54 PM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 06:36 PM
Expand rough opening in load bearing wall msaunders Building & Construction 1 10-04-2010 08:59 PM
Bifold doors -- non-standard rough opening michelob Remodeling 5 05-19-2009 12:19 AM
Trimmer joists-expanding a rough opening benjamincall Carpentry 2 05-16-2009 06:40 PM
