Rough Opening For 30x80 Door? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-23-2015, 04:31 PM   #1
Rewards Points: 336
rough opening for 30x80 door?
Just wanted to make sure I get the frame built out correctly.
I'm adding a 30x80 door I read that you're supposed to add 2" to the width and 2.5 for the height but found a manual on homedepot sit that says it my rough opening should be 32.5 wide and 82 tall. I know it's only half an inch but since I'm building it out wanted to make sure it's done right from the get go to reduce the amount of shimming at the end.
dannieboiz is offline   Reply With Quote
Old 11-23-2015, 05:15 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,742
Figure on a 32" by 82" RO.
The Following User Says Thank You to Windows on Wash For This Useful Post:
ben's plumbing (11-23-2015)
Old 11-23-2015, 05:54 PM   #3
Rewards Points: 582
it is smaller than 32 x 82 but that is for making sure you have room to square and shim where needed for a nice install...
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (11-23-2015)
Old 11-23-2015, 06:34 PM   #4
Rewards Points: 336
Sounds good I'll do an 33x83 cause who know how this old house has shifted after 30 years. LOL
JK I'll do 32x82
Rough opening width for prehung door.. hboogz Carpentry 22 05-01-2013 03:16 PM
Making rough opening narrower?? ratherbefishing Carpentry 8 09-27-2011 03:57 PM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
