Rough In For 60" Interior French Doors Issue - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-05-2011, 09:32 AM   #1
Rewards Points: 204
Rough in for 60" interior french doors issue
I am finishing my basement and I framed out 62 inches for 60 inch french doors....well I didn't hang the drywall until a year later and the jack\king studs kind of bowed. I didn't notice it and the hangers went ahead and hung the drywall. I decided to remeasure all of my door openings before I ordered my doors and the rough in ranges from 61 3/8" to 62". Will I have an issue getting the door in? If so what can I do?
Thanks!
Abs777 is offline   Reply With Quote
Old 05-05-2011, 03:24 PM   #2
kwikfishron's Avatar
Rewards Points: 996
Most French Doors the RO will be between 63-64”. You’ll need to remodel the opening, including the header. What brand of door?
kwikfishron is online now   Reply With Quote
Old 05-06-2011, 08:34 AM   #3
Rewards Points: 204
The door is Jeld-Wen. I checked the specs and it says the rough opening needs to be at least 61 1/2. I think I can make it work. I would think trimming the doors and jam would be easier than ripping out the opening and having to reframe and drywall...no?
Old 05-06-2011, 05:04 PM   #4
Rewards Points: 996
There’s a few ways to do it. You can cut the sheetrock nails and push it over with a 62” block and re-nail. If the wall’s “Not Load Bearing” you can remove the 2x trimmer and replace with a thinner one. You Can plane it. If I was doing it I’d probably grab the Big Foot and get that bump out of my way.
Old 05-06-2011, 05:16 PM   #5
KemoSabe
loneframer's Avatar
62 inch RO would most likely have ball catches, rather than a T-astragal where the doors meet. That's fine if it's a door to a common area. If you're looking for privacy, not the best choice. They are generally used for closet doors.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 05-06-2011, 09:09 PM   #6
Rewards Points: 5,336
You would base the rough opening of a door unit based on a specific door.
If the RO changed due to warping of material, you would remove the warped goods and reframe the opening.
Ron
Issue with Anderson French Door. Help Please. dorothyolive Building & Construction 21 05-19-2014 10:18 AM
Can doors installed brick be reversed FuLLTiLT Building & Construction 7 01-10-2010 07:52 AM
New Interior doors don't close properly jdhar Building & Construction 3 09-15-2009 10:08 AM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 05:26 PM
UGH! A lesson for new Pre-Hung Doors javan General DIY Discussions 6 08-08-2008 07:47 PM
