Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 04-13-2011, 07:29 PM   #1
Rotting Threshold/Door/Siding
I’ve replaced the door and it’s working well but I need to fix another problem. I’m not sure what direction to go. I replaced the door because of rotting caused by poor water drainage. I’ve attached a few photos that should help understand this particular situation.
The roof is angled where a lot of water is deposited in one location, right next to the door. The step below the door isn’t angled enough, creating standing water. As you can see there is also water damage in the corner of the house where the roof sections meet.
I’m not sure how to take on the task of fixing it. Not sure if there is something I can buy to place in the corner to keep water off the porch and from running down the side of the house. Should I just put another layer of concrete on the porch and create the correct angle? What could be done besides that and what are the best options.
Thanks for any help or suggestions.
Rotting Threshold/Door/Siding-doorthreshold.jpg   Rotting Threshold/Door/Siding-largeview.jpg   Rotting Threshold/Door/Siding-waterdamage.jpg
jbt411 is offline   Reply With Quote
Old 04-13-2011, 08:26 PM   #2
Moderator
kwikfishron's Avatar
Well lets see, a gutter would be a good start. No roof overhang over the door, a awning would help. A storm door would be a good addition also.
Once you have the causes dealt with the you can spend a few on the damage.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 06-08-2011, 01:38 PM   #3
www.doors4home.com
jason.r's Avatar
I would recommend installing gutters to divert the rainwater away from this area of the house. The siding needs a lot of work and the door needs to be sealed in.
The aluminium threshold looks to be in good condition except the picture makes the door look like it has slope towards the inside of the house. I would see if the threshold is adjustable first and maybe bring it up a bit and check the door shoe for replacement.
An awning would also help keep the rain from pounding on that door.
Jason
jason.r is offline   Reply With Quote
Tags
level foundation, porch, roof, roof angle
my fix for rotting outside sill on wooden window guest General Discussion 6 11-06-2010 03:58 PM
How to prevent tree stump from rotting? Jeremy Hillary Boob, PhD Landscaping & Lawn Care 8 06-21-2009 09:16 AM
Rotting shower walls PICTURE Sarah24 Kitchen & Bath Remodeling 6 05-10-2009 01:09 AM
Celebration FL home rotting - HELP Celebration Homeowner General Discussion 4 06-14-2008 08:27 PM
Rotting Rim board baianodiy Building & Construction 1 11-10-2007 08:11 AM
