-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Rotting Threshold/Door/Siding (http://www.diychatroom.com/f104/rotting-threshold-door-siding-101424/)
jbt411 04-13-2011 07:29 PM
3 Attachment(s)
Iíve replaced the door and itís working well but I need to fix another problem. Iím not sure what direction to go. I replaced the door because of rotting caused by poor water drainage. Iíve attached a few photos that should help understand this particular situation.
The roof is angled where a lot of water is deposited in one location, right next to the door. The step below the door isnít angled enough, creating standing water. As you can see there is also water damage in the corner of the house where the roof sections meet.
Iím not sure how to take on the task of fixing it. Not sure if there is something I can buy to place in the corner to keep water off the porch and from running down the side of the house. Should I just put another layer of concrete on the porch and create the correct angle? What could be done besides that and what are the best options.
Thanks for any help or suggestions.
kwikfishron 04-13-2011 08:26 PM
199 Attachment(s)
Well lets see, a gutter would be a good start. No roof overhang over the door, a awning would help. A storm door would be a good addition also.
Once you have the causes dealt with the you can spend a few on the damage.
jason.r 06-08-2011 01:38 PM
I would recommend installing gutters to divert the rainwater away from this area of the house. The siding needs a lot of work and the door needs to be sealed in.
The aluminium threshold looks to be in good condition except the picture makes the door look like it has slope towards the inside of the house. I would see if the threshold is adjustable first and maybe bring it up a bit and check the door shoe for replacement.
An awning would also help keep the rain from pounding on that door.
Jason
