Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 08-13-2011, 06:04 PM   #1
m1951mm's Avatar
Rotted wood in sill
While painting around a vinyl window I saw that there is a 2x4 between the bottom of the window (the vinyl itself) and the drywall. It is half rotted out. How do I replace the wood and how much of the drywall do I need to cut out to do this? I am assuming that there are studs on either side of the window and that the window is secured to them so if I remove the rotten 2x4 under the window it will not come crashing down on me or the floor (bottom level of a trilevel, so the garden is right there). I am am thinking that I have to remove the casing (two sides and the bottom) and cut drywall and get the cats paw out. Since I have to replace some drywall would I be better off going beyond the studs so I can better support the new "footer" or is that overkill and I just need to toenail in the new piece.
m1951mm is offline   Reply With Quote
Old 08-14-2011, 10:26 AM   #2
Moderator
kwikfishron's Avatar
Rotted wood in sill
You don’t want to remove any more drywall than necessary.
If its just the sill you should be able to keep the drywall damage within the casing.
If you have wood jambs you should be able to make the repair with no mud work necessary.
Post a picture of what your dealing with.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Mud sill with vapor barrier and gasket - treated or untreated wood? dwoloz Building & Construction 2 06-03-2011 10:20 AM
easiest/proper way to repair rotted pine roof wood noquacks Roofing 5 05-16-2011 10:35 PM
Wood Under Door Sill is Rotted rgmetro Building & Construction 14 11-19-2010 01:24 AM
wood piece underneath front door sill llckll Flooring 1 08-25-2009 07:12 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
