Rotted Window Sill Replacement - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-27-2014, 08:43 PM   #1
Rewards Points: 33
Normally this is something that is beyond my skill set (or lack thereof) but I have some window sills that need replacing and am looking for some advice.
First off, pardon my lack of vocabulary. No window sill replacement info I have found on the internet is like mine. The windows I am referring to have a formed metal plate that the regular window and the storm window sit on. Beneath that is the actual wooden sill. The metal portion does not appear to sit on the wooden portion, which are so bad they are just about falling out.
Because they are so badly rotted, I cannot even tell how they attach to the side of the house, and without being able to find windows with this design, I cant look it up on the internet.
I will post pics tomorrow as it is night and raining right now.
Any help would be greatly appreciated!
bigbopper180 is offline   Reply With Quote
Old 07-27-2014, 09:07 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
Pics will help greatly.
Old 07-27-2014, 11:29 PM   #3
Rewards Points: 332
Send a message via Yahoo to curtd
Yep, pics very helpful. In one old house there at one time existed only wood double sash windows. Sounds surreal, but true. Then along came aluminum storm windows. The metal plate (aluminum) was needed because in between the double sash and storm window (winter time) condensation occurred and this metal plate keeps the sill from rotting from standing water issues. A little simplistic solution (bc i'm not there) is detach the metal plate from the sill, install new sill and reattach the metal plate to the sill using caulking. This sounds easy right? Sorry, but i know it is not so easy as i make it to sound (labor wise)
curtd is offline   Reply With Quote
Old 07-28-2014, 02:08 PM   #4
Rewards Points: 144
"The windows I am referring to have a formed metal plate that the regular window and the [COLOR=blue !important][COLOR=blue !important]storm [COLOR=blue !important]window[/COLOR][/COLOR][/COLOR] sit on."
Curtd: I think your thinking of the wrong parts as he stated the" regular window And the storm window sit on them".I would also like to see a pic so we both can tell for sure.
I know what your referring to and they should not be caulked .They have weep holes in them and this is what lets the condensation escape.
mako1 is offline   Reply With Quote
Old 07-28-2014, 04:35 PM   #5
Rewards Points: 33
As promised, below are some pictures. I removed one of the sills and broke it down. There were a couple insects but luckily no termites.
Behind the rotten piece I removed there is still non-rotted wood. Now I'm just not sure how best to replace it. Can I nail a replacement piece straight into the wood that was behind it, paint it and caulk it?
After tearing the piece out I'm thinking this may not be as difficult as I originally thought.
Old 07-28-2014, 04:42 PM   #6
Rewards Points: 14,000
Impossible to tell much from those pictures.
To small, can not even tell what's there siding.
Are they aluminum storm windows that someone sealed the drain holes or there plugged up with dirt?
Old 07-28-2014, 06:35 PM   #7
Rewards Points: 144
Yeh, looks like you took those pics from the top of a tree.Can we see some pics of the issue from ground level.Don't mean to be picky but can't even see the sill and the problem.
Help Installing replacement window with Z-bar djstepanich Windows and Doors 7 03-02-2014 02:09 PM
Rotted window sill pinkertonpv Windows and Doors 10 06-14-2012 07:34 PM
Replacing window sill, but now it's stuck. rosemonster Carpentry 25 01-25-2011 04:31 AM
Window Replacement mark2741 Remodeling 5 07-21-2010 03:33 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
