Reversing An Exterior Door? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-21-2014, 03:58 PM   #1
Rewards Points: 162
Reversing an exterior door?
Is it possible to install an exterior door backwards?
I am looking to replace a storm door on my vacation home. The door leaks air and actually chills down the whole place during the winter. It has opening windows that we really don't need. Due to the location, I cannot simply install an exterior door that opens inwards. I believe the solution will be to buy an exterior door that has hinges on the right and install it with the hinges on the left. I realize that the weatherstripping on the inside of the door may not be entirely adequate, but think that the pros outweigh the cons.
Will I have difficulty in opening the door?
Thanks in advance.
RumDiet is offline   Reply With Quote
Old 12-21-2014, 04:23 PM   #2
Rewards Points: 6,652
Yes it would be easy. But the problem is that you are now going to have a hole where the handle was on the side that it previously was. But that can be fixed with some bondo & spray paint.
You just have to move the Hinge Z-Bar to the side that the handle is on, and move the handle to the side that the Hinge Z-Bar previously was.
If it is leaking air, that just means that you just really have to adjust the Z-Bars, to get rid of the gaps, and maybe replace the bottom sweep.
Old 12-21-2014, 04:32 PM   #3
Rewards Points: 162
Hmm - didn't think of the pre-drilled holes.
What is a Hinge Z-Bar?
Problem with the present storm door is that it doesn't seem to have enough insulation and the windows leak - its a new door from a major and highly rated manufacturer.
Old 12-21-2014, 06:13 PM   #4
Rewards Points: 12,886
I'm confused. A picture would sure help.
Reversing the swing on any door is a royal pain, replacing with an outswing prehung door makes more since to me and may not even be needed.
Millions of homes have no storm doors and are leak free, so more info and a picture would be a big help.
I've worked on many a 100 year old house with original doors and managed to make them air leak free with no storm door.
Old 12-21-2014, 06:27 PM   #5
As for the Exterior door itself. You would have to pull the door, the frame and install a new one that swings inwards. If there is a porch or deck that sits even with the door, it can allow water inside of the exterior door was not properly installed, or weatherstripping not maintained.
Old 12-21-2014, 07:05 PM   #6
Rewards Points: 162
Greg - I need a door that swings out - not in - present storm door swings out - I want to replace it with a better insulated door. I am just not seeing outward swinging exterior doors. No porch on the outside. Door leads to 2 steps down - then the porch.
Joe - yes buying a out swinging door would be the best solution - and I would buy a out swinging exterior door if I could find one. Do they even make them?
this is the door we have (my hinges are on the left side)
Old 12-21-2014, 08:07 PM   #7
All storm doors swing out. Exterior doors have to swing in, unless on a commercial building.
Right now you have a Right Swing door for the storm. Cannot tell from your picture what swing your interior door is. It all depends on if you want a Right Swing or Left Swing for the doors.
Old 12-21-2014, 08:29 PM   #8
kwikfishron's Avatar
Rewards Points: 92
Out-swing residential exterior doors although not the norm are defiantly available and I've installed a handful of the over the years for various reasons.
I've never seen a storm door that swings in though.
kwikfishron is online now   Reply With Quote
Old 12-21-2014, 08:31 PM   #9
Rewards Points: 162
Greg - I have no exterior door - ALL I have is the storm door. Is there some law or something that says all exterior doors have to swing in????
My original question is whether or not it would be possible to buy an exterior door and reverse it so that it swings out.
Old 12-21-2014, 08:44 PM   #10
Rewards Points: 92
No there is not.
You don't buy a door and "reverse it", you simply just have to order an "out-swing" door.
The Following 3 Users Say Thank You to kwikfishron For This Useful Post:
gregzoll (12-21-2014), Hick (12-21-2014), oh'mike (12-21-2014)
Old 12-21-2014, 09:21 PM   #11
DIY staff
Rewards Points: 7,174
Yep--order an outswing door---it has a different threshold than an inswing door---so don't attempt to reverse an inswing--it will leak.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Old 12-21-2014, 09:36 PM   #12
If all you have is a storm door and no real exterior solid door then of course you have issues.
Storm doors where never intended to be the only door.
gregzoll (12-22-2014)
Old 12-21-2014, 10:40 PM   #13
Rewards Points: 1,910
If you just install a prehung inswing exterior door backwards so it swings out then the threshold will slope wrong and your door hinges will be on the outside. Might as well not bother locking the door because anyone can just pull the hinge pins and walk right in.
The Following User Says Thank You to jogr For This Useful Post:
Old 12-21-2014, 11:38 PM   #14
Rewards Points: 162
so where can I order a out swinging exterior door?
Old 12-22-2014, 12:40 AM   #15
Any Big Box hardware store, local lumber yard. If it is a common size, they may have some basic doors in stock.
The Following User Says Thank You to gregzoll For This Useful Post:
oh'mike (12-22-2014)
Goodman Heat Pump Jumpered Reversing Valve tom1336 HVAC 14 07-21-2012 03:11 AM
O or B reversing valve on my heat pump? RobinFL HVAC 8 04-18-2012 04:57 PM
testing reversing valve wetbar HVAC 2 05-26-2011 08:43 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
reversing contactors, dismantle and modify shag_carpet Electrical 9 02-05-2010 03:29 PM
