Reverse Door Swing From Left To Right - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-17-2012, 08:55 PM   #1
silverph's Avatar
Rewards Points: 12
Reverse door swing from left to right
The current (wood) door opens from right to left. I need it to open from left to right (same side). Can this be done and does anybody have steps for me to follow? Carve new openings for the hinges and door knob? Turn door upside down? :P
Thank you.
Brian
silverph is offline   Reply With Quote
Old 04-17-2012, 09:28 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Hinges are not as big an issue, but the doorknob may be. Is the interior and exterior the same wood finish? ... Is this an interior or exterior door?
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
dougp23 (04-18-2012)
Old 04-17-2012, 09:47 PM   #3
silverph's Avatar
Rewards Points: 12
It is a door in the basement (interior) and door is painted the same inside and out (plain white).
Old 04-18-2012, 01:08 AM   #4
Rewards Points: 13,270
If it's just a cheap MDF door just replace it. There not very expencive.
If you look on Craigs list under materails you may find one cheaper then at the store.
If it's some solid expencive door then remove it and turn it around.
Old 04-18-2012, 06:51 AM   #5
silverph's Avatar
Rewards Points: 12
I really didn't want to spend more than the cost of a few tools needed to convert it. If this can't be done without replacing anything, I can live with the current setup.
Old 04-18-2012, 10:46 AM   #6
MJW
I agree. Replace it with a whole new door or leave it alone. You would end up spending an entire day messing with it and it probably won't turn out too well in the end. You would probably end up going and buying a new one the next day anyways.
MJW is offline   Reply With Quote
The Following User Says Thank You to MJW For This Useful Post:
Old 04-18-2012, 11:02 AM   #7
Ironlight's Avatar
It can be done and it's not too hard, but it depends on the vintage of the door and the hardware. Obviously if it is an older door and matches the style of the home you'll want to keep it.
The first thing you want to ascertain is whether the door will fit when flipped. In older homes this is not a given if there has been any settling. Simply take it off the hinges, flip it, and see if it fits in the opening. If it does, you're good to go.
With it flipped over and in the opening, mark off where the top and bottom of the hinges will be on the other side of the door casing. If necessary, slip a shim under the door to raise it in the opening to the appropriate height. Also mark the centerline for the door latch.
Chisel out rabbets for the hinges in the casing. Drill out the hole for the latch, and chisel out for the latch plate.
Disassemble the doorknob/latch mechanism and flip it over so that it now works for the reverse side. If this is an older door with one of those older tall narrow mechanisms, open it up and simply flip the latch over so it faces the other direction. Reinstall.
Fill all the voids on the old side with wood filler, sand prime etc.
Hang the door, with the hinges affixed to the door, starting with one screw in the top hinge, then one in the bottom, and when you have the right position, drill and screw the rest of them. This prevents binding from misaligned hinges.
DO NOT simply flip the door upside down. That's a total hack and results in the doorknob being at the wrong height.
Ironlight is offline   Reply With Quote
The Following User Says Thank You to Ironlight For This Useful Post:
silverph (04-20-2012)
Old 04-20-2012, 07:54 AM   #8
silverph's Avatar
Rewards Points: 12
Thank you! I think this is a simple project for me to try.
Old 04-20-2012, 11:39 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
One possible down side to turning the door around would be if the door is beveled, as most are, then you will have problems. Doors most times are beveled so the edge will clear the jamb when opened and closed. If the door edges are beveled there is only two options that I see, make the door swing in instead of out or plug the holes and hinge mortises and start over.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Arkitexas (04-23-2012)
Old 04-20-2012, 12:02 PM   #10
silverph's Avatar
Rewards Points: 12
It is a terribly simple ugly door. :P I'll remove it over the weekend and test fit it.
Moving a socket from left and stud to right hand stud(and up 3 feet) raptor_demon Electrical 19 04-03-2012 11:27 AM
HOT / NEUTRAL REVERSE.... need help to fix DIYneedsHelp Electrical 10 10-05-2009 07:36 PM
Kinetico Water Softeners -Reverse Osmosis Questions...Help - Advice wanted.. OverRunWithSons Plumbing 7 07-26-2009 01:14 AM
Changing reverse osmosis water filters awayeli General DIY Discussions 2 07-05-2008 03:20 PM
Reverse Wiring (Hotwiring), Penny in Old Fuse Box rlmarr Electrical 14 03-28-2008 06:42 PM
