Retrofit Window Question - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-02-2013, 05:32 PM   #1
Retrofit window question
I accidentally put this question in the wrong section. Oops
I plan on replacing my 25 year old aluminum windows with some vinyl retrofits. The window guy at the local big box store told me I would get the best fit and a slightly larger window if I cut away the aluminum flanges ( I think that it what it's called) that protrude inward from the frame and install the window directly over the frame. After looking online, I can't find any reference to this being done. Is this a good idea? Thanks.
TomJ204 is offline   Reply With Quote
Old 02-02-2013, 06:21 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Hard to say for sure... A pic would be great.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 02-02-2013, 06:29 PM   #3
From outside
Old 02-02-2013, 06:32 PM   #4
The metal the sales person said should be cut away. Basically, trim away what ever protrudes from the drywall.
Old 02-02-2013, 06:55 PM   #5
Rewards Points: 6,652
With the structure having Stucco, you are really looking at a lot of work to get it correct. That means that you may end up having to pay someone to come in and repair any Stucco that was cut away, so you can get the new window units installed properly. Retrofit windows, fit in the frame, but in your case, you would need "New" Construction type windows.
Not something for the faint of heart, if they do not have the time or tools to do the work properly, and correct. Now you can check with a local glass shop, and see if they are able to manufacture replacement slides that are double or triple pane, that would just go back into the frames.
Old 02-02-2013, 07:02 PM   #6
Thanks for the reply.
The sales person is selling me the retrofit windows. However, rather than the new window fitting in the old frame as it is currently, he said for me to cut away the metal flanges on the old frame that separates the window from the screen. The new window would then rest on the portion of the old frame that remains.
Old 02-02-2013, 08:14 PM   #7
747
registered
747's Avatar
Rewards Points: 534
Don't listen to this sales person. This has to be handled just rite. I like the ideal going to a glass company and seeing if they have double or triple slides or having them come out and take a look and explain your options. This is stucco. This is a tough job which as to be handle by a guy who KNOWS WHAT HE IS DOING.
747 is offline   Reply With Quote
Retrofit Window Question TomJ204 Building & Construction 3 02-03-2013 07:59 AM
Header question - raising door and window RO enoll Building & Construction 10 05-04-2012 05:39 PM
window trim question blackestate Windows and Doors 22 09-21-2011 02:38 PM
quick door and window question wengang1 Drywall & Plaster 4 12-09-2010 05:24 PM
Retrofit Window Installation typerr Remodeling 4 10-28-2009 12:47 PM
