Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 07-20-2012, 07:20 AM   #1
retrofit vinyl windows- using wood trim on inside
I often see installers use vinyl strips to finish and cover the gap between the existing metal window frame and the new vinyl window frame, seen from the inside of the room.
Looks tacky to me.
I was thinking about using 1/2-3/4" fiberboard to create a sill to obscure the gap, plus finish with moulding around the edge, like pic below..
Is it ok to butt the fiberboard/plywood against retrofit vinyl window like that?
Will there be expansion/warping issues?
pman6 is offline   Reply With Quote
Old 07-20-2012, 03:34 PM   #2
Exterior Construction
Windows on Wash's Avatar
Totally fine.
Don't smash it into it, but leave yourself a small caulk joint.
Old 07-20-2012, 05:33 PM   #3
Moderator
kwikfishron's Avatar
Use a siliconized acrylic latex caulking.
Do not use 100% silicone caulk.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Vinyl Perf Soffit over Wood - No Vents nickelshine Roofing 18 05-29-2012 10:12 AM
White trim vs wood trim mamamonika Woodworking 0 02-11-2012 11:31 PM
Vinyl flooring over wood slat subfloor Patricia54 Flooring 6 02-11-2012 03:22 PM
White vinyl windows with wood trim... crazy? rnjsbungalow Interior Decorating 5 04-16-2009 06:53 AM
