Retractable Clear Vinyl Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-23-2012, 01:10 PM   #1
Retractable clear vinyl window
I'm building a woodworking enclosure inside the middle of a 3 car enclosed garage. The walls will be 2x4 16" centers. I want window openings to permit visibility and light. Single hung vinyl window and screen runs about $125 at Lowes for 4'x4'. Is anyone aware of a "window" with a screen and a clear vinyl panel that would both retract into cassettes built into the frame?
Blitzkow is offline   Reply With Quote
Old 03-23-2012, 04:11 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
If you go to a glass shop with a drawing of what you are trying to do they can probably supply you with the right materials to build it. I've never seen anything like that, so it would probably have to be custom built.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
What is "backing support" for vinyl window installation? Brennus Building & Construction 5 04-27-2011 07:11 PM
Oak casing to a vinyl jamb extension on a new window? Dustball Carpentry 13 04-14-2010 12:06 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 06:29 PM
Window Frame Materials - Vinyl vs Aluminum vs Fiberglass chrison600 Building & Construction 2 10-09-2005 12:13 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
