Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 07-20-2012, 03:32 PM   #1
Restoring Wood Door, a couple questions...
My house was built in 1939 and has a rounded door that I am going to try to restore this weekend. Two main questions:
1) Their is a vertical crack in one part of the door where it looks like the "panels" have ever so slightly separated, enough so that you can see light coming through. What we be the best way to fix this? Glue, Epoxy, Caulk, something else? I'd like to fix it right and be done with it.
Crack:
https://www.dropbox.com/s/d34gpcwxuk72gh7/20120720_131852.jpg
2) Their is a gap at the bottom of one side of the door that is pretty substantial, I'm guess it is due to the door having been shaved at one point and then the house shifting. I was thinking of something like a door shoe to even it out:
Here is the gap:
https://www.dropbox.com/s/1nh2ih7zjl...720_140955.jpg
archangelus2 is offline   Reply With Quote
Old 07-20-2012, 08:51 PM   #2
Super Moderator
The metal door bottom will be good---adding an adjustable thresh hold would also help to seal up that gap--
As to the separated panel---a photo from further back would be helpful--but I think an epoxy poured ihto the crack might be the answer---
Old 07-21-2012, 06:06 AM   #3
Is that daylight between the panels, or old paint?? If old paint, it is a T&G panel that has moved a bit or shrunk up. Door panels in panel doors are supposed to be able to move/breathe. If they can't, they often split somewhere. That split can be repaired but it is usually temporary, and will reappear there or somewhere else as the wood breathes.
If daylight, could be hard to fix. As suggested a different pic might help us.
Old 07-21-2012, 11:38 AM   #4
Definitely day light coming through the crack.
Wood floor types and maintenance questions Green Cleaner Flooring 5 03-23-2011 05:47 PM
Couple Questions on installing real wood 4x8 beadboard paneling (Georgia Pacific) RickDel Carpentry 4 07-07-2010 03:46 PM
A couple of questions about stairs. Omega Supreme Carpentry 5 09-26-2009 07:07 PM
couple of code questions ponch37300 Electrical 9 01-26-2009 11:45 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
