Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 06-20-2011, 06:03 PM   #16
Moderator
kwikfishron's Avatar
Replacing Windows... How Do I seal the Outside Gaps?
Originally Posted by HomeSealed View Post
An insert style window (goes inside your existing frame) can be installed and flashed effectively in that application (not just relying on caulk), however it is a "higher-level" task. Most guys would probably do it it the cheap way as ron warned against. Most times in situations where we are dealing with condo associations,etc, they have preferred the insert style as we can get the trim to mimic the original look and match more closely to the other units. The fact that you have no 1xX or brickmold around the exterior would pretty much necessitate the removal of all of the surrounding siding for a full tear-out, due to the fact that as you described, the HOA/Condo Assoc. probably won't accept fat trim around the opening. A full tear-out of that nature is also a pretty high-level installation. I really don't recommend DIY either way, or anytime where substantial flashing detail is necessary, but I guess this is the DIY forum, right? Just do alot of research, maybe find some good youtube videos or something.... Messing up twin casements would be a pricey mistake.
HomeSealed, if you install the window within the frame as you mention how does that change the trim detail on the inside?
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 06-20-2011, 08:10 PM   #17
Tom Struble's Avatar
that could be anything from wider trim to butting new to existing trim
Tom Struble is offline   Reply With Quote
Old 06-20-2011, 09:07 PM   #18
Moderator
I don’t see butting the original. I see either all new trim or a big ass ¼ round or something.
Either way a new look on the inside(not acceptable to some). There would be some cost to benefit issues to weigh there.
-NEW MEMBERS-
Old 06-20-2011, 10:06 PM   #19
the association will dictate the install,simple as that
The Following User Says Thank You to Tom Struble For This Useful Post:
HomeSealed (06-20-2011)
Old 06-20-2011, 10:17 PM   #20
Windows & Remodeling
HomeSealed's Avatar
When you say "inside" do you mean interior? If so, in that app we'd either add a quarter round or parting stop (1/2 x 3/4) style moulding to act as an interior stop. Every time that I've worked with condo associations, etc, their jurisdiction (and their concern) ends on the exterior... FWIW, I do agree that a full tear-out is preferable, it just tends not to fall that way when uniformity and cost concerns come into play.
HomeSealed is offline   Reply With Quote
Replacing Windows x106 Windows and Doors 14 04-15-2011 10:48 AM
Replacing old aluminum windows cocean Building & Construction 2 01-13-2010 06:55 AM
Replacing Old Windows pyrogen74 Remodeling 1 02-09-2006 07:53 PM
Replacing Windows shronnnda Remodeling 8 05-10-2005 01:44 PM
Replacing windows silverado692 General Discussion 3 11-06-2004 10:42 PM
