Replacing Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-27-2013, 05:30 PM   #1
Replacing windows
Am going through the process of replacing some rather old, metal frame windows. As I am a typical DIY guy, I got a few quotes an now want to see what it's ganna cost me to do it. I have replaced windows before but it was a generic vinyl to vinyl same size replacement, no questions asked. Now I am going from a large single metal frame to 3 double hung vinyls. I just cut open the inside portion of the metal from and got down to the ruff 2x4 opening. Just trying to get an idea for how to measure when going from one opening to 3. I will frame out each window and allow for a shim tolerance but not sure how much of a tolerance I will need. Any one got suggestions?
Weaver1463 is offline   Reply With Quote
Old 10-12-2013, 11:51 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,224
Post up some pictures to start with.
Old 10-12-2013, 11:58 AM   #3
Rewards Points: 13,960
Really would have been better to order the windows first since it may take two weeks to get them.
Also best because often times the ordered size and the one's you receive can be slightly different.
Old 10-15-2013, 04:35 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
It sounds as though you are putting 3 windows into one opening? If so, the best but would be to get them factory mulled (put together at the factory) and not frame in each one individually. You could also look at something like a 3 lite slider as opposed to the 3 double hungs if cost is a major concern.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 10-15-2013, 07:24 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,242
standard practice for all windows is to frame the opening 1" larger both in height and width. this allows for proper shimming and space for spray foam insulation
woodworkbykirk is offline   Reply With Quote
Replacing the glass in single pane wood windows. Halo2jak Windows and Doors 11 05-28-2013 05:30 PM
Replacing Windows in home with LOTS of wood DomiFamily Building & Construction 0 05-14-2013 11:38 AM
Replacing windows - masonry construction katit Remodeling 4 05-18-2010 12:52 PM
Replacing Windows (Which Brand?) dixieman Remodeling 3 04-30-2009 06:45 PM
Replacing Windows shronnnda Remodeling 8 05-10-2005 12:44 PM
